Automate watch cinema routine
I am trying to automate my Watch Cinema routine. What I am trying to achieve is that, when watch cineme activity (Harmony) is on, I need to control my projector screen (which is connected by a relay) and my light. I want the projector relay to open and after 38 seconds stop. At the same time I want the my corner lamp to come on, change the colour temp the warmest, wait 30 seconds and the fade level to 30% gradually. And after 5 minutes to 10%.
I am managing to do this currently, but I am having to use 2 different pistons. Is that the right way to do it? can I do it with a single piston?.
If I try to do it with one piston, ST wait for the screen to come all the way down (38 seconds) and then start turning on the lights etc.
icon to show the statement options. When you set the Execution Method to Asynchronous the single piston should split and run the two separate action blocks at the same time.
