- I have 5 AC units in my house (not central, these are individual wall units)
- All controlled with ZXT IR devices (I can see them in ST and webcore etc)
- They all have the same setup
- But each room has different temp as X
- And I don’t want them all working the same time, so I created 5 pistons. Each room has it’s own piston
IF temp raises above X degrees
With ZXT IR garage
TURN ON
SET TO COOL
IF temp drops below X degrees
With ZXT IR garage
TURN OF
**I don’t know which way is better (maybe doesn’t even matter) **
Create 5 pistons OR single piston with 5 ACs in it?
With ZXT IR garage
TURN ON
SET TO COOL
With ZXT IR garage
TURN OF
With ZXT IR movieroom
TURN ON
SET TO COOL
TURN OF
With ZXT IR mbedroom
TURN ON
SET TO COOL
TURN OF
With ZXT IR guestroom
TURN ON
SET TO COOL
TURN OF
With ZXT IR livingroom
TURN ON
SET TO COOL
TURN OF
Thank you all…
