Of course! Should’ve done that earlier. Also when I’m in the field of the sensor and im.still moving, it just turns off the light and takes ages to recover, of course it should be overlapping. I’ve already tried two sensors, a Philips hue sensor (st dh) and a Xiaomi sensor.
Code; o3tq8
Kitchensensor 2 rules
Status
This piston is currently active and humming happily.
Pause »
Piston Category
Nothing selected Doorsensors statusTemperature statusBattery statusPistons
Quick Facts
Piston state: false
Last executed: 12/4/2018, 7:28:16 AM
Next scheduled: 12/4/2018, 7:28:15 AM
Subscriptions: 1 event, 6 controls
Devices used: 7
Memory used: 67% (67163 bytes)
External URL: (click to open/execute)
Automatic Backup
Automatic backup enabled.
Touch the box to reveal your backup bin code. Make a note of this code as you may use it later to restore a deleted piston.
o3tq8
Do NOT share this code with anyone.
Script
///* Kitchensensor 2 rules *////* Author : Kitchen sensor workinprogress // Created : 7/19/2018, 1:40:21 AM // Modified : 11/30/2018, 8:54:33 PM // Build : 4 // UI version : v0.3.108.20180906 //**************************************************************/ +0msstart/ Trace started on 12/4/2018, 7:28:16 AM (about 1 minute ago) */ execute+383ms97ms
if /* #1 */
Sensor Kitchen New’s motionchanges to active/* #7 */
and
Goodnight’s switchis off /* #17 */
then+393ms87ms
if /* #8 */
Time is between12:00:00 AM and{$sunset} /* #16 */
then+397ms82ms
with /* #12 */Dimmable light 5, Dimmable light 4, andDimmable light 2do
Set level to 50%; /* #13 */
+424ms▼ ▼ ▼ Wait 2minutes; /* #14 */
+425ms53ms Turn off; /* #15 */
end with;
else
with /* #2 */afzuigkap links,afzuigkap rechts,Dimmable light 2, Dimmable light 4, andDimmable light 5do
Set level to 50%; /* #9 */
Wait 2minutes; /* #10 */
Set level to 1%; /* #11 */
end with;
end if;
end if;
+481msdoneend execute; +525msstop/* Trace ended on 12/4/2018, 7:28:17 AM */
Logs
12/4/2018, 7:28:16 AM +686ms
+2ms ╔Received event [Sanctuary].time = 1543904895529 with a delay of 1156ms
+333ms ║RunTime Analysis CS > 214ms > PS > 46ms > PE > 73ms > CE
+347ms ║Runtime (37605 bytes) successfully initialized in 46ms (v0.2.0e1.20170728) (342ms)
+349ms ║╔Execution stage started
+442ms ║║Executed physical command [Dimmable light 5].off() (14ms)
+444ms ║║Executed [Dimmable light 5].off (16ms)
+460ms ║║Executed physical command [Dimmable light 4].off() (14ms)
+461ms ║║Executed [Dimmable light 4].off (16ms)
+477ms ║║Executed physical command [Dimmable light 2].off() (14ms)
+478ms ║║Executed [Dimmable light 2].off (16ms)
+493ms ║╚Execution stage complete. (144ms)
+501ms ╚Event processed successfully (501ms)
12/4/2018, 7:26:46 AM +256ms
+1ms ╔Received event [Sensor Kitchen New].motion = inactive with a delay of 90ms
+117ms ║RunTime Analysis CS > 22ms > PS > 39ms > PE > 56ms > CE
+128ms ║Runtime (37601 bytes) successfully initialized in 39ms (v0.2.0e1.20170728) (126ms)
+140ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+142ms ║║Cancelling condition #7’s schedules…
+143ms ║║Condition #7 evaluated false (8ms)
+144ms ║║Cancelling condition #1’s schedules…
+145ms ║║Condition group #1 evaluated false (state changed) (11ms)
+160ms ║╚Execution stage complete. (31ms)
+162ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:28:15 AM CET (in 89.112s)
+181ms ╚Event processed successfully (181ms)
12/4/2018, 7:26:15 AM +206ms
+2ms ╔Received event [Sensor Kitchen New].motion = active with a delay of 91ms
+152ms ║RunTime Analysis CS > 27ms > PS > 69ms > PE > 56ms > CE
+162ms ║Runtime (37606 bytes) successfully initialized in 69ms (v0.2.0e1.20170728) (160ms)
+163ms ║╔Execution stage started
+175ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+177ms ║║Cancelling condition #7’s schedules…
+178ms ║║Condition #7 evaluated true (9ms)
+188ms ║║Comparison (enum) off is (string) off = true (2ms)
+190ms ║║Condition #17 evaluated true (11ms)
+191ms ║║Cancelling condition #1’s schedules…
+192ms ║║Condition group #1 evaluated true (state changed) (23ms)
+238ms ║║Comparison (time) 26775402 is_between (time) 0 … (datetime) 1543936740000 = true (8ms)
+239ms ║║Time restriction check passed
+241ms ║║Condition #16 evaluated true (46ms)
+242ms ║║Condition group #8 evaluated true (state did not change) (47ms)
+245ms ║║Cancelling statement #12’s schedules…
+268ms ║║Executed physical command [Dimmable light 5].setLevel([50]) (15ms)
+269ms ║║Executed [Dimmable light 5].setLevel (17ms)
+297ms ║║Executed physical command [Dimmable light 4].setLevel([50]) (26ms)
+298ms ║║Executed [Dimmable light 4].setLevel (27ms)
+316ms ║║Executed physical command [Dimmable light 2].setLevel([50]) (15ms)
+317ms ║║Executed [Dimmable light 2].setLevel (17ms)
+321ms ║║Executed virtual command [Dimmable light 5, Dimmable light 4, Dimmable light 2].wait (1ms)
+322ms ║║Requesting a wake up for Tue, Dec 4 2018 @ 7:28:15 AM CET (in 120.0s)
+328ms ║╚Execution stage complete. (165ms)
+330ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:28:15 AM CET (in 119.994s)
+347ms ╚Event processed successfully (347ms)
12/4/2018, 7:25:45 AM +306ms
+1ms ╔Received event [Sensor Kitchen New].motion = inactive with a delay of 95ms
+320ms ║RunTime Analysis CS > 31ms > PS > 234ms > PE > 55ms > CE
+330ms ║Runtime (37603 bytes) successfully initialized in 234ms (v0.2.0e1.20170728) (328ms)
+331ms ║╔Execution stage started
+341ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+343ms ║║Cancelling condition #7’s schedules…
+344ms ║║Condition #7 evaluated false (6ms)
+345ms ║║Cancelling condition #1’s schedules…
+346ms ║║Condition group #1 evaluated false (state changed) (9ms)
+348ms ║╚Execution stage complete. (18ms)
+355ms ╚Event processed successfully (354ms)
12/4/2018, 7:23:46 AM +198ms
+5ms ╔Received event [Sanctuary].time = 1543904625590 with a delay of 605ms
+2500ms ║RunTime Analysis CS > 2345ms > PS > 67ms > PE > 91ms > CE
+2514ms ║Runtime (37599 bytes) successfully initialized in 67ms (v0.2.0e1.20170728) (2503ms)
+2515ms ║╔Execution stage started
+2615ms ║║Executed physical command [Dimmable light 5].off() (14ms)
+2617ms ║║Executed [Dimmable light 5].off (18ms)
+2634ms ║║Executed physical command [Dimmable light 4].off() (13ms)
+2634ms ║║Executed [Dimmable light 4].off (15ms)
+2650ms ║║Executed physical command [Dimmable light 2].off() (13ms)
+2651ms ║║Executed [Dimmable light 2].off (15ms)
+2666ms ║╚Execution stage complete. (152ms)
+2674ms ╚Event processed successfully (2674ms)
12/4/2018, 7:21:45 AM +319ms
+1ms ╔Received event [Sensor Kitchen New].motion = active with a delay of 82ms
+123ms ║RunTime Analysis CS > 31ms > PS > 39ms > PE > 53ms > CE
+132ms ║Runtime (37606 bytes) successfully initialized in 39ms (v0.2.0e1.20170728) (130ms)
+133ms ║╔Execution stage started
+143ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+145ms ║║Cancelling condition #7’s schedules…
+146ms ║║Condition #7 evaluated true (7ms)
+155ms ║║Comparison (enum) off is (string) off = true (2ms)
+157ms ║║Condition #17 evaluated true (9ms)
+158ms ║║Cancelling condition #1’s schedules…
+159ms ║║Condition group #1 evaluated true (state changed) (19ms)
+200ms ║║Comparison (time) 26505481 is_between (time) 0 … (datetime) 1543936740000 = true (8ms)
+201ms ║║Time restriction check passed
+202ms ║║Condition #16 evaluated true (40ms)
+203ms ║║Condition group #8 evaluated true (state did not change) (42ms)
+206ms ║║Cancelling statement #12’s schedules…
+229ms ║║Executed physical command [Dimmable light 5].setLevel([50]) (17ms)
+230ms ║║Executed [Dimmable light 5].setLevel (19ms)
+248ms ║║Executed physical command [Dimmable light 4].setLevel([50]) (15ms)
+249ms ║║Executed [Dimmable light 4].setLevel (17ms)
+264ms ║║Executed physical command [Dimmable light 2].setLevel([50]) (13ms)
+265ms ║║Executed [Dimmable light 2].setLevel (15ms)
+270ms ║║Executed virtual command [Dimmable light 5, Dimmable light 4, Dimmable light 2].wait (0ms)
+271ms ║║Requesting a wake up for Tue, Dec 4 2018 @ 7:23:45 AM CET (in 120.0s)
+277ms ║╚Execution stage complete. (144ms)
+279ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:23:45 AM CET (in 119.993s)
+297ms ╚Event processed successfully (297ms)
12/4/2018, 7:16:09 AM +85ms
+1ms ╔Received event [Sanctuary].time = 1543904169393 with a delay of -308ms
+135ms ║RunTime Analysis CS > 28ms > PS > 40ms > PE > 66ms > CE
+146ms ║Runtime (37604 bytes) successfully initialized in 40ms (v0.2.0e1.20170728) (144ms)
+147ms ║╔Execution stage started
+197ms ║║Executed physical command [Dimmable light 5].off() (15ms)
+198ms ║║Executed [Dimmable light 5].off (18ms)
+214ms ║║Executed physical command [Dimmable light 4].off() (14ms)
+215ms ║║Executed [Dimmable light 4].off (16ms)
+233ms ║║Executed physical command [Dimmable light 2].off() (14ms)
+234ms ║║Executed [Dimmable light 2].off (16ms)
+238ms ║╚Execution stage complete. (90ms)
+246ms ╚Event processed successfully (246ms)
12/4/2018, 7:14:39 AM +128ms
+1ms ╔Received event [Sensor Kitchen New].motion = inactive with a delay of 112ms
+122ms ║RunTime Analysis CS > 36ms > PS > 33ms > PE > 53ms > CE
+136ms ║Runtime (37602 bytes) successfully initialized in 33ms (v0.2.0e1.20170728) (135ms)
+147ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+148ms ║║Cancelling condition #7’s schedules…
+149ms ║║Condition #7 evaluated false (6ms)
+151ms ║║Cancelling condition #1’s schedules…
+151ms ║║Condition group #1 evaluated false (state changed) (9ms)
+155ms ║╚Execution stage complete. (19ms)
+157ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:16:09 AM CET (in 90.108s)
+176ms ╚Event processed successfully (176ms)
12/4/2018, 7:14:09 AM +144ms
+1ms ╔Received event [Sensor Kitchen New].motion = active with a delay of 92ms
+114ms ║RunTime Analysis CS > 20ms > PS > 40ms > PE > 53ms > CE
+128ms ║Runtime (37606 bytes) successfully initialized in 40ms (v0.2.0e1.20170728) (126ms)
+140ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+143ms ║║Condition #7 evaluated true (7ms)
+153ms ║║Comparison (enum) off is (string) off = true (2ms)
+155ms ║║Condition #17 evaluated true (11ms)
+156ms ║║Cancelling condition #1’s schedules…
+157ms ║║Condition group #1 evaluated true (state changed) (22ms)
+201ms ║║Comparison (time) 26049305 is_between (time) 0 … (datetime) 1543936740000 = true (8ms)
+202ms ║║Time restriction check passed
+204ms ║║Condition #16 evaluated true (44ms)
+205ms ║║Condition group #8 evaluated true (state did not change) (45ms)
+209ms ║║Cancelling statement #12’s schedules…
+222ms ║║Skipped execution of physical command [Dimmable light 5].setLevel([50]) because it would make no change to the device. (6ms)
+223ms ║║Executed [Dimmable light 5].setLevel (8ms)
+232ms ║║Skipped execution of physical command [Dimmable light 4].setLevel([50]) because it would make no change to the device. (7ms)
+233ms ║║Executed [Dimmable light 4].setLevel (9ms)
+242ms ║║Skipped execution of physical command [Dimmable light 2].setLevel([50]) because it would make no change to the device. (7ms)
+243ms ║║Executed [Dimmable light 2].setLevel (9ms)
+248ms ║║Executed virtual command [Dimmable light 5, Dimmable light 4, Dimmable light 2].wait (1ms)
+249ms ║║Requesting a wake up for Tue, Dec 4 2018 @ 7:16:09 AM CET (in 120.0s)
+255ms ║╚Execution stage complete. (126ms)
+257ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:16:09 AM CET (in 119.993s)
+277ms ╚Event processed successfully (276ms)
12/4/2018, 7:13:17 AM +413ms
+1ms ╔Received event [Sensor Kitchen New].motion = inactive with a delay of 80ms
+106ms ║RunTime Analysis CS > 17ms > PS > 34ms > PE > 56ms > CE
+118ms ║Runtime (37601 bytes) successfully initialized in 34ms (v0.2.0e1.20170728) (117ms)
+119ms ║╔Execution stage started
+130ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+132ms ║║Cancelling condition #7’s schedules…
+133ms ║║Condition #7 evaluated false (7ms)
+134ms ║║Cancelling condition #1’s schedules…
+135ms ║║Condition group #1 evaluated false (state changed) (9ms)
+138ms ║╚Execution stage complete. (18ms)
+139ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:14:40 AM CET (in 82.827s)
+160ms ╚Event processed successfully (160ms)
12/4/2018, 7:12:39 AM +90ms
+3ms ╔Received event [Sensor Kitchen New].motion = active with a delay of 1327ms
+1121ms ║RunTime Analysis CS > 983ms > PS > 61ms > PE > 77ms > CE
+1135ms ║Runtime (37610 bytes) successfully initialized in 61ms (v0.2.0e1.20170728) (1129ms)
+1136ms ║╔Execution stage started
+1154ms ║║Comparison (enum) active changes_to (string) active = true (2ms)
+1156ms ║║Cancelling condition #7’s schedules…
+1157ms ║║Condition #7 evaluated true (12ms)
+1167ms ║║Comparison (enum) off is (string) off = true (3ms)
+1169ms ║║Condition #17 evaluated true (11ms)
+1170ms ║║Cancelling condition #1’s schedules…
+1171ms ║║Condition group #1 evaluated true (state changed) (26ms)
+1222ms ║║Comparison (time) 25960265 is_between (time) 0 … (datetime) 1543936740000 = true (10ms)
+1223ms ║║Time restriction check passed
+1225ms ║║Condition #16 evaluated true (51ms)
+1226ms ║║Condition group #8 evaluated true (state did not change) (52ms)
+1229ms ║║Cancelling statement #12’s schedules…
+1253ms ║║Skipped execution of physical command [Dimmable light 5].setLevel([50]) because it would make no change to the device. (7ms)
+1254ms ║║Executed [Dimmable light 5].setLevel (9ms)
+1270ms ║║Skipped execution of physical command [Dimmable light 4].setLevel([50]) because it would make no change to the device. (13ms)
+1271ms ║║Executed [Dimmable light 4].setLevel (14ms)
+1280ms ║║Skipped execution of physical command [Dimmable light 2].setLevel([50]) because it would make no change to the device. (7ms)
+1281ms ║║Executed [Dimmable light 2].setLevel (8ms)
+1286ms ║║Executed virtual command [Dimmable light 5, Dimmable light 4, Dimmable light 2].wait (1ms)
+1288ms ║║Requesting a wake up for Tue, Dec 4 2018 @ 7:14:40 AM CET (in 120.0s)
+1343ms ║╚Execution stage complete. (208ms)
+1351ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:14:40 AM CET (in 119.939s)
+1369ms ╚Event processed successfully (1369ms)
12/4/2018, 7:12:08 AM +323ms
+2ms ╔Received event [Sensor Kitchen New].motion = inactive with a delay of 94ms
+112ms ║RunTime Analysis CS > 23ms > PS > 34ms > PE > 55ms > CE
+127ms ║Runtime (37601 bytes) successfully initialized in 34ms (v0.2.0e1.20170728) (124ms)
+128ms ║╔Execution stage started
+139ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+140ms ║║Cancelling condition #7’s schedules…
+141ms ║║Condition #7 evaluated false (7ms)
+142ms ║║Cancelling condition #1’s schedules…
+143ms ║║Condition group #1 evaluated false (state changed) (9ms)
+147ms ║╚Execution stage complete. (19ms)
+148ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:13:35 AM CET (in 87.196s)
+169ms ╚Event processed successfully (169ms)
12/4/2018, 7:11:35 AM +431ms
+1ms ╔Received event [Sensor Kitchen New].motion = active with a delay of 77ms
+104ms ║RunTime Analysis CS > 18ms > PS > 32ms > PE > 53ms > CE
+116ms ║Runtime (37606 bytes) successfully initialized in 32ms (v0.2.0e1.20170728) (114ms)
+117ms ║╔Execution stage started
+127ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+129ms ║║Cancelling condition #7’s schedules…
+130ms ║║Condition #7 evaluated true (7ms)
+139ms ║║Comparison (enum) off is (string) off = true (2ms)
+141ms ║║Condition #17 evaluated true (9ms)
+143ms ║║Condition group #1 evaluated true (state changed) (19ms)
+188ms ║║Comparison (time) 25895577 is_between (time) 0 … (datetime) 1543936740000 = true (9ms)
+189ms ║║Time restriction check passed
+191ms ║║Condition #16 evaluated true (45ms)
+192ms ║║Condition group #8 evaluated true (state did not change) (46ms)
+195ms ║║Cancelling statement #12’s schedules…
+208ms ║║Skipped execution of physical command [Dimmable light 5].setLevel([50]) because it would make no change to the device. (5ms)
+209ms ║║Executed [Dimmable light 5].setLevel (7ms)
+218ms ║║Skipped execution of physical command [Dimmable light 4].setLevel([50]) because it would make no change to the device. (7ms)
+219ms ║║Executed [Dimmable light 4].setLevel (8ms)
+228ms ║║Skipped execution of physical command [Dimmable light 2].setLevel([50]) because it would make no change to the device. (7ms)
+229ms ║║Executed [Dimmable light 2].setLevel (9ms)
+233ms ║║Executed virtual command [Dimmable light 5, Dimmable light 4, Dimmable light 2].wait (1ms)
+235ms ║║Requesting a wake up for Tue, Dec 4 2018 @ 7:13:35 AM CET (in 120.0s)
+241ms ║╚Execution stage complete. (123ms)
+242ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:13:35 AM CET (in 119.994s)
+262ms ╚Event processed successfully (261ms)
12/4/2018, 7:11:05 AM +575ms
+1ms ╔Received event [Sensor Kitchen New].motion = inactive with a delay of 84ms
+105ms ║RunTime Analysis CS > 18ms > PS > 32ms > PE > 54ms > CE
+119ms ║Runtime (37601 bytes) successfully initialized in 32ms (v0.2.0e1.20170728) (116ms)
+133ms ║║Condition #7 evaluated false (6ms)
+139ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:12:35 AM CET (in 90.177s)
+161ms ╚Event processed successfully (160ms)
12/4/2018, 7:10:35 AM +657ms
+1ms ╔Received event [Sensor Kitchen New].motion = active with a delay of 79ms
+103ms ║RunTime Analysis CS > 16ms > PS > 34ms > PE > 53ms > CE
+114ms ║Runtime (37606 bytes) successfully initialized in 34ms (v0.2.0e1.20170728) (113ms)
+115ms ║╔Execution stage started
+126ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+128ms ║║Cancelling condition #7’s schedules…
+129ms ║║Condition #7 evaluated true (8ms)
+140ms ║║Comparison (enum) off is (string) off = true (2ms)
+141ms ║║Condition #17 evaluated true (11ms)
+143ms ║║Condition group #1 evaluated true (state changed) (22ms)
+186ms ║║Comparison (time) 25835805 is_between (time) 0 … (datetime) 1543936740000 = true (8ms)
+187ms ║║Time restriction check passed
+189ms ║║Condition #16 evaluated true (42ms)
+190ms ║║Condition group #8 evaluated true (state did not change) (43ms)
+193ms ║║Cancelling statement #12’s schedules…
+206ms ║║Skipped execution of physical command [Dimmable light 5].setLevel([50]) because it would make no change to the device. (5ms)
+207ms ║║Executed [Dimmable light 5].setLevel (7ms)
+215ms ║║Skipped execution of physical command [Dimmable light 4].setLevel([50]) because it would make no change to the device. (6ms)
+216ms ║║Executed [Dimmable light 4].setLevel (8ms)
+225ms ║║Skipped execution of physical command [Dimmable light 2].setLevel([50]) because it would make no change to the device. (7ms)
+226ms ║║Executed [Dimmable light 2].setLevel (9ms)
+231ms ║║Executed virtual command [Dimmable light 5, Dimmable light 4, Dimmable light 2].wait (1ms)
+233ms ║║Requesting a wake up for Tue, Dec 4 2018 @ 7:12:35 AM CET (in 120.0s)
+239ms ║╚Execution stage complete. (124ms)
+241ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:12:35 AM CET (in 119.993s)
+259ms ╚Event processed successfully (259ms)
12/4/2018, 7:09:47 AM +813ms
+1ms ╔Received event [Sensor Kitchen New].motion = inactive with a delay of 83ms
+143ms ║RunTime Analysis CS > 39ms > PS > 50ms > PE > 53ms > CE
+156ms ║Runtime (37601 bytes) successfully initialized in 50ms (v0.2.0e1.20170728) (153ms)
+156ms ║╔Execution stage started
+167ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+169ms ║║Cancelling condition #7’s schedules…
+170ms ║║Condition #7 evaluated false (7ms)
+171ms ║║Cancelling condition #1’s schedules…
+172ms ║║Condition group #1 evaluated false (state changed) (10ms)
+179ms ║╚Execution stage complete. (22ms)
+180ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:10:54 AM CET (in 66.251s)
+208ms ╚Event processed successfully (208ms)
12/4/2018, 7:08:53 AM +998ms
+117ms ║RunTime Analysis CS > 30ms > PS > 32ms > PE > 55ms > CE
+129ms ║Runtime (37606 bytes) successfully initialized in 32ms (v0.2.0e1.20170728) (126ms)
+146ms ║║Condition #7 evaluated true (8ms)
+158ms ║║Condition group #1 evaluated true (state changed) (21ms)
+201ms ║║Comparison (time) 25734159 is_between (time) 0 … (datetime) 1543936740000 = true (9ms)
+204ms ║║Condition #16 evaluated true (43ms)
+208ms ║║Cancelling statement #12’s schedules…
+221ms ║║Skipped execution of physical command [Dimmable light 5].setLevel([50]) because it would make no change to the device. (6ms)
+222ms ║║Executed [Dimmable light 5].setLevel (8ms)
+229ms ║║Skipped execution of physical command [Dimmable light 4].setLevel([50]) because it would make no change to the device. (5ms)
+230ms ║║Executed [Dimmable light 4].setLevel (6ms)
+239ms ║║Skipped execution of physical command [Dimmable light 2].setLevel([50]) because it would make no change to the device. (6ms)
+240ms ║║Executed [Dimmable light 2].setLevel (8ms)
+244ms ║║Executed virtual command [Dimmable light 5, Dimmable light 4, Dimmable light 2].wait (1ms)
+245ms ║║Requesting a wake up for Tue, Dec 4 2018 @ 7:10:54 AM CET (in 120.0s)
+251ms ║╚Execution stage complete. (122ms)
+253ms ║Setting up scheduled job for Tue, Dec 4 2018 @ 7:10:54 AM CET (in 119.994s)
+272ms ╚Event processed successfully (272ms)
