Smart lock help
Hello,
I’m trying to build a piston that will notify me when my smart lock gets unlocked, and see what code has been use, to tell me who is home (me and my wife have a different code)
How can I manage to see what code has been use? I see those 2 codes in smartlock smartapps in ST but can’t find those in webcore
Please advise
thanks!
What lock do you have?
I’m using a Schlage BE469 with the ethayer smartapp/DTH. It can’t report the code used, but it can report the slot used. So my piston looks something like this:
If front door lock’s LOCK#1 gets unlocked
Send push notification “front door unlocked by wife”
If front door lock’s LOCK#3 gets unlocked
Send push notification “front door unlocked by nephew”
Etc.
That could be done more compactly using arrays, but it works as-is so I have no incentive to rebuild it.
Anyway, you get the idea. Long as you know which code is in which slot, it’s pretty straightforward.
Hello
I have a Schlage century lock.
In webcore, I saw the code #1-2-3-4-5-6 but I was trying to figure which code was in each slot
So it mean I must create a piston and test it with both code to have my answer
thanks
