Would like to use webCoRE for SmartThings presence.
- Installed webCoRE SmartApps in SmartThings IDE.
- Created a simulated switch in SmartThings IDE.
- Installed webCoRE app for iOS.
- Created automations in SmartThings to arm or disarm depending on simulated switch status.
I can see the iPhone tiles in the webCoRE dashboard app. The tile appears to work, turning gray when not present and colored when present. I can also see the simulated switch in SmartThings.
SmartThings to use presence from webCoRE
The simulated switch device in IDE inidcates âNo data found for device.â The switch does not change to âon.â
