When I create a new piston and with an action to execute a Routine, the Value field is an empty text box. It used to show a dropdown of all my Routines. May have something to do with the downtime that happened last night? Also, none of the Routines that should execute as part of existing pistons seem to be executing. In existing pistons, in the place of the name of the routine, I see a hex string like “:0249587123a13476b23:”
See a dropdown of Routines in the create Piston flow, and pistons show back up in my existing pistons.
See above
