More of a general debugging question. I seem to have a light that gets triggered by something. It could be some routine from GH, but I suspect I may have a typo somewhere in one of the pistons. I was wondering if there is an easy way to look at the event happening around that time and figure out what piston (if it was a piston) triggered that light. Thanks!
Some kind of global log
eibyer
I am not sure if you can still sign up for an IDE account at smartthings but that’s one of the ways you can see historical logs for the device events.
Might be a question for the folks more up to date in the ST forums.
vv2020
So let’s say one suspects that a piston tigger’s a device it should not. Is there a way to sort out which piston was the trigger? Is there a device view of sorts. Thanks
