Greetings…
All I added to my IF’s in my piston is STAYS and it seems not to trigger anymore.
My piston is supposed to run when there’s motion upstairs at a certain time in the morning. So…
- (The main IF) Sensor changes to active
… then the rest are a check for when … - Kettle Switch has been turned on for at least 10 minutes
… comes on via my phone alarm… - It’s dark outside
- a certain switch is off
- Location Mode is HOME
… do the rest of the piston if all conditions are met.
BUT… I think the STAYS is the issue (it’s the only thing new added).
I don’t wan’t it to be a trigger, just a check to see if kettle was turned on for at least 10 minutes after being off all night.
Am I using or misunderstanding STAYS? Is there an alternative just to check?
Thanks in advance for any suggestions.
