Hi everyone,
Simple question… but I can’t find out why it does not work.
I am trying to have my sonos player to play a mp3 sound in a piston.
Thanks for your help
Greg
Hi everyone,
Try this mp3…
https:// s3.amazonaws.com/smartapp-media/sonos/dogs.mp3
I placed a space before s3 that you will need to remove
Just FYI, whatever MP3 you end up using, you should still follow @jkp’s original suggestion to remove the volume setting option. There have been previous threads discussing the fact that tracks don’t play if the volume option is set. Just use a separate “set level” action before “play track.”
thanks to all !!
Update : I was a bit optimistic… in fact sonos was playing the lastest track I played trough the sonos app, not the one given in the webcore piston url…
I was having the same problem and nothing worked.
Later on due to changing wifi router I had to add sonos speakers from scratch.
After adding them all, play track started working flawlessly.
Just an idea.
