Last year I created a piston to create a visible (bulb colour change) and audible (Sonos playing a track) when the room temperature exceeds a threshold. This is needed because the gas fire is not thermostatically controlled.
Bulb colour change and sound file played over Sonos speakers when temperature trigger is reached
Bulb colour changes on trigger condition but sound is no longer played when piston executes on specified condition
Sonos is working in it’s normal way
Sound file still plays from URL
06/10/2021, 10:02:57 +718ms
+1ms ╔Received event [lounge].temperature = 20.9 with a delay of 42ms
+29ms ║RunTime Analysis CS > 12ms > PS > 4ms > PE > 13ms > CE
+31ms ║Runtime (36874 bytes) successfully initialized in 4ms (v0.3.110.20191009) (29ms)
+32ms ║╔Execution stage started
+40ms ║║Comparison (decimal) 20.9 rises_above (decimal) 20.8 = true (1ms)
+42ms ║║Cancelling condition #2’s schedules…
+43ms ║║Condition #2 evaluated true (5ms)
+44ms ║║Cancelling condition #1’s schedules…
+44ms ║║Condition group #1 evaluated true (state changed) (8ms)
+47ms ║║Cancelling statement #3’s schedules…
+56ms ║║Executed physical command [Kitchen].playTrack([http://www.xxx.org.uk/wp-content/uploads/2020/12/jnglbell.wav]) (4ms)
+57ms ║║Executed [Kitchen].playTrack (6ms)
+62ms ║║Executed physical command [Living room].playTrack([http://www.xxx.org.uk/wp-content/uploads/2020/12/jnglbell.wav]) (3ms)
+63ms ║║Executed [Living room].playTrack (5ms)
+66ms ║║Cancelling statement #5’s schedules…
+72ms ║║Executed physical command [xxx Light].setColor([[hex: #FF0000, hue:0, saturation:100, level:50]]) (2ms)
+73ms ║║Executed [xxx Light].setColor (4ms)
+76ms ║╚Execution stage complete. (44ms)
+77ms ╚Event processed successfully (77ms)
