Hi. I’m a relatively new WebCoRE user, I’m using Z-Wave blinds controllers, wifi switches, hue lights, a Neato vacuum, z-wave button controllers and some more devices to automate my home. I’m currently using a SmartThings hub and it’s mostly OK but the thing I don’t like is the lag between button pushes and actions.
I’ve been reading a bit about Hubitat and I’m interested in this option to run WebCoRE locally, but there are some devices like my Neato vacuum which are not compatible with Hubitat. I would like to know if it is possible to migrate all my compatible devices to my Hubitat and leave those which are not compatible in the SmartThings environment, and have two WebCoRE instances interacting. For example, when I leave home my blinds close and my Neato vacuum cleans the floors, and I already have all these pistons working perfectly. Is it possible to move the buttons and blinds to Hubitat and link the devices easily inside the WebCoRE pistons?
I understand that those devices that are on the ST network will not be available if the network is down, and will keep being laggy, but is it possible (and easy) to have the best of both worlds?
Thanks,
Rodrigo
