This piston is supposed to lock the door if open for 15 min after sunset. I also wanted it to lock the door if it was unlocked after sunset it does not do that. I get mixed up with these pistons sometimes. I was told that I should always have a trigger at the start. Otherwise, I would change the first line (trigger) to time is between (condition) Would that work?
Thanks Gord
Starting piston with an action
Gord
guxdude
Just trying to understand. Right now, it looks like the first trigger will lock the door if it is locked AT sunset (not any other time). The second trigger should lock the door anytime after sunset if it is unlocked and stays that way for 15 minutes. Is that not what you want? What are the conditions you actually want?
