I’m trying to use the “stays” condition to see if a switch/contact sensor stays in the same state for X minutes. But even after the switch/contact goes back to the non-event state, the statements inside the condition.
For example, I have a condition that a contact sensor stays open for 15 minutes. If that occurs, send me an SMS.
I opened the door at 5:21:56, this triggered a scheduled task for 5:36:56. I closed it at 5:22:00. I expected the “stays” condition to evaluate to false in this situation.
But the event at 5:36:56 still fired! In addition to that, even though the condition was not satisfied, it still sent the SMS!
> 11/12/2019, 5:36:55 PM +59ms
> +1ms ╔Received event [Home].time = 1573598216427 with a delay of -1368ms
> +111ms ║RunTime Analysis CS > 20ms > PS > 50ms > PE > 41ms > CE
> +114ms ║Runtime (37967 bytes) successfully initialized in 50ms (v0.3.110.20191009) (113ms)
> +115ms ║╔Execution stage started
> +120ms ║║Cancelling condition #2’s schedules…
> +121ms ║║Condition #2 evaluated true (1ms)
> +122ms ║║Cancelling condition #1’s schedules…
> +123ms ║║Condition group #1 evaluated true (state changed) (3ms)
> +125ms ║║Cancelling statement #3’s schedules…
> +130ms ║║Calculating (string) Garage Door + (string) stayed open! >> (string) Garage Door stayed open!
> +169ms ║║Executed virtual command sendSMSNotification (35ms)
> +171ms ║╚Execution stage complete. (56ms)
> +172ms ╚Event processed successfully (172ms)
> 11/12/2019, 5:22:00 PM +219ms
> +1ms ╔Received event [Garage Door].contact = closed with a delay of 123ms
> +206ms ║RunTime Analysis CS > 20ms > PS > 46ms > PE > 140ms > CE
> +208ms ║Runtime (37967 bytes) successfully initialized in 46ms (v0.3.110.20191009) (206ms)
> +209ms ║╔Execution stage started
> +229ms ║║Comparison (enum) closed stays (string) open = false (2ms)
> +231ms ║║Comparison (enum) closed stays (string) open = false (1ms)
> +233ms ║║Comparison (enum) open stays (string) open = true (1ms)
> +235ms ║║Comparison (enum) closed stays (string) open = false (1ms)
> +238ms ║║Cancelling any timed trigger schedules for device :ceccd13059dfba8762c8e0392de30fbc: for condition 2
> +239ms ║║Cancelling statement #2’s schedules…
> +239ms ║║Cancelling any timed trigger schedules for device :d4714e580b9f31d2af8aad8acc1373a3: for condition 2
> +240ms ║║Cancelling statement #2’s schedules…
> +241ms ║║Cancelling any timed trigger schedules for device :bbb7a11842b6bfb119c90dbb63bc2013: for condition 2
> +242ms ║║Cancelling statement #2’s schedules…
> +243ms ║║Condition #2 evaluated false (30ms)
> +244ms ║║Condition group #1 evaluated false (state did not change) (31ms)
> +247ms ║╚Execution stage complete. (37ms)
> +248ms ║Setting up scheduled job for Tue, Nov 12 2019 @ 5:36:56 PM EST (in 895.961s)
> +261ms ╚Event processed successfully (260ms)
> 11/12/2019, 5:21:56 PM +278ms
> +1ms ╔Received event [Garage Door].contact = open with a delay of 101ms
> +111ms ║RunTime Analysis CS > 20ms > PS > 49ms > PE > 42ms > CE
> +113ms ║Runtime (37961 bytes) successfully initialized in 49ms (v0.3.110.20191009) (111ms)
> +114ms ║╔Execution stage started
> +136ms ║║Comparison (enum) closed stays (string) open = false (1ms)
> +138ms ║║Comparison (enum) closed stays (string) open = false (1ms)
> +140ms ║║Comparison (enum) open stays (string) open = true (1ms)
> +143ms ║║Comparison (enum) open stays (string) open = true (2ms)
> +145ms ║║Cancelling any timed trigger schedules for device :ceccd13059dfba8762c8e0392de30fbc: for condition 2
> +146ms ║║Cancelling statement #2’s schedules…
> +147ms ║║Cancelling any timed trigger schedules for device :d4714e580b9f31d2af8aad8acc1373a3: for condition 2
> +148ms ║║Cancelling statement #2’s schedules…
> +149ms ║║Adding a timed trigger schedule for device :c58071b876c8d1c7be089868f62cead0: for condition 2
> +151ms ║║Adding a timed trigger schedule for device :bbb7a11842b6bfb119c90dbb63bc2013: for condition 2
> +153ms ║║Cancelling condition #2’s schedules…
> +154ms ║║Condition #2 evaluated false (35ms)
> +155ms ║║Cancelling condition #1’s schedules…
> +156ms ║║Condition group #1 evaluated false (state changed) (38ms)
> +159ms ║╚Execution stage complete. (45ms)
> +161ms ║Setting up scheduled job for Tue, Nov 12 2019 @ 5:36:56 PM EST (in 899.989s), with 1 more job pending
> +170ms ╚Event processed successfully (169ms)
