When I disarm STHM, siren still sounds
I have a delay set in STHM to allow a someone to walk in the door and disarm the alarm at a Panel using Actiontiles.
The alarm gets triggered as an intrusion, which I know is the intended reaction; however, I would like to “dismiss” the intrusion if the alarm is disarmed at the panel. I don’t know how to start the piston using the “intrusion” as the trigger. YES, I did read and there are similar questions, but mostly pertaining to SHM and not STHM. Thank you!
