Hello, I’ve noticed something weird with my Hue bulbs and I was wondering if there is something I can do to fix it. I have two pistons that do the exact same thing but I only have one of them active at a time to test between them.
On one, the group of Hue lights is defined as a device variable and that variable is used throughout the piston. With this one, whenever the device variable gets sent “Turn Off”, the Hue bulbs turn off instantly without dimming.
Here:
On the second, the Hue lights are defined in-line instead of through a variable. With this one, whenever the list of Hue lights gets sent “Turn Off”, the Hue bulbs fade off.
Here:
Why is there a difference and is there something I can do to make them consistent? I’m trying to make template pistons like the first one that I can easily change for each room instead of going through and changing everything line by line, but I would want the bulbs to dim.
