In webCoRE I wrote some code to achive the following: When a door sensor is open for more then 20 seconds a push notification is sent to me every 20 seconds. If the door sensor get the state closed within 20 seconds nothing happens. But if the door is closed after a push message you get push notification with the text “Thanks for closing door”. When I het this script working I’ll let mij Google Nest Mini talk the notifications.
I expect that the script should run ok, but the variable “dooropened” seems to lose the valie "true"after leaving the repeat loop en get the value “false”, which causes the if-statement after the repeat loop not to trigger the push notification.
The variable “dooropened” doens’t retain its value after leaving the repeat loop.
(UPLOAD YOUR IMAGE HER
1/13/2021, 9:45:18 PM +112ms
+1ms ╔Received event [My home].time = 1610570719202 with a delay of -1090ms
+79ms ║RunTime Analysis CS > 39ms > PS > 4ms > PE > 36ms > CE
+82ms ║Runtime (39653 bytes) successfully initialized in 4ms (v0.3.110.20191009) (80ms)
+84ms ║╚Execution stage complete. (2ms)
+85ms ╚Event processed successfully (85ms)
1/13/2021, 9:45:09 PM +710ms
+1ms ╔Received event [Door sesnsor test].contact = closed with a delay of 77ms
+45ms ║RunTime Analysis CS > 13ms > PS > 4ms > PE > 28ms > CE
+48ms ║Runtime (39648 bytes) successfully initialized in 4ms (v0.3.110.20191009) (46ms)
+49ms ║╔Execution stage started
+52ms ║║Cancelling statement #23’s schedules…
+58ms ║║Executed virtual command setVariable (2ms)
+64ms ║║Comparison (enum) closed is (string) open = false (1ms)
+65ms ║║Cancelling condition #2’s schedules…
+66ms ║║Condition #2 evaluated false (6ms)
+67ms ║║Cancelling condition #1’s schedules…
+68ms ║║Condition group #1 evaluated false (state changed) (7ms)
+70ms ║╚Execution stage complete. (21ms)
+71ms ╚Event processed successfully (70ms)
1/13/2021, 9:44:59 PM +41ms
+0ms ╔Received event [My home].time = 1610570699997 with a delay of -957ms
+55ms ║RunTime Analysis CS > 16ms > PS > 4ms > PE > 35ms > CE
+57ms ║Runtime (39645 bytes) successfully initialized in 4ms (v0.3.110.20191009) (56ms)
+58ms ║╔Execution stage started
+103ms ║║Comparison (enum) open is (string) open = true (1ms)
+105ms ║║Condition #10 evaluated true (34ms)
+106ms ║║Condition group #9 evaluated true (state did not change) (35ms)
+108ms ║║Cancelling statement #18’s schedules…
+114ms ║║Executed virtual command setVariable (3ms)
+131ms ║║Executed virtual command sendPushNotification (11ms)
+150ms ║║Comparison (enum) open is (string) closed = false (1ms)
+152ms ║║Condition #6 evaluated false (19ms)
+153ms ║║Condition group #5 evaluated false (state did not change) (21ms)
+155ms ║║Cancelling statement #7’s schedules…
+159ms ║║Executed virtual command wait (0ms)
+160ms ║║Requesting a wake up for Wed, Jan 13 2021 @ 9:45:19 PM CET (in 20.0s)
+165ms ║╚Execution stage complete. (106ms)
+166ms ║Setting up scheduled job for Wed, Jan 13 2021 @ 9:45:19 PM CET (in 19.996s)
+172ms ╚Event processed successfully (172ms)
1/13/2021, 9:44:39 PM +912ms
+2ms ╔Received event [Door sesnsor test].contact = open with a delay of 119ms
+52ms ║RunTime Analysis CS > 18ms > PS > 5ms > PE > 28ms > CE
+54ms ║Runtime (39655 bytes) successfully initialized in 5ms (v0.3.110.20191009) (51ms)
+55ms ║╔Execution stage started
+60ms ║║Cancelling statement #23’s schedules…
+65ms ║║Executed virtual command setVariable (3ms)
+71ms ║║Comparison (enum) open is (string) open = true (1ms)
+73ms ║║Cancelling condition #2’s schedules…
+74ms ║║Condition #2 evaluated true (7ms)
+75ms ║║Cancelling condition #1’s schedules…
+76ms ║║Condition group #1 evaluated true (state changed) (9ms)
+79ms ║║Cancelling statement #7’s schedules…
+83ms ║║Executed virtual command wait (0ms)
+84ms ║║Requesting a wake up for Wed, Jan 13 2021 @ 9:44:59 PM CET (in 20.0s)
+89ms ║╚Execution stage complete. (34ms)
+90ms ║Setting up scheduled job for Wed, Jan 13 2021 @ 9:44:59 PM CET (in 19.995s)
+111ms ╚Event processed successfully (111ms)
