Have a string var message. A tigger if message changes, then message sends to web requests. However, the trigger does not happen. In the UI next to the statement has no orange lighting icon.
It should be trigger so when the message value changes, the web requests should be sent.
It’s not running.
1/11/2022, 11:29:14 AM +21ms
+1ms ╔Starting piston… (v0.3.113.20210203)
+1796ms ║╔Subscribing to devices…
+1854ms ║║Subscribing to Slide Door.contact…
+1869ms ║║Subscribing to Flood Light.switch…
+1959ms ║╚Finished subscribing (177ms)
+2033ms ║Comparison (time) 41356001 is_between (time) 1641940920000 … (time) 1641907200000 = false (11ms)
+2057ms ║Comparison (enum) off is (string) off = true (2ms)
+2078ms ║Comparison (enum) off stays (string) on = false (1ms)
+2109ms ║Comparison (enum) off is (string) on = false (1ms)
+2131ms ║Comparison (time) 41356137 is_between (time) 1641907200000 … (time) 1641940920000 = true (10ms)
+2132ms ║Time restriction check passed
+2144ms ║Comparison (enum) off is (string) on = false (2ms)
+2152ms ║Comparison (string) Backyard flood light has been on for 2 hours. changes = false (1ms)
+2162ms ╚Piston successfully started (2162ms)
1/11/2022, 11:28:18 AM +852ms
+2048ms ║╔Subscribing to devices…
+2111ms ║║Subscribing to Slide Door.contact…
+2124ms ║║Subscribing to Flood Light.switch…
+2219ms ║╚Finished subscribing (183ms)
+2283ms ║Comparison (time) 41301091 is_between (time) 1641940920000 … (time) 1641907200000 = false (12ms)
+2304ms ║Comparison (enum) off is (string) off = true (2ms)
+2324ms ║Comparison (enum) off stays (string) on = false (2ms)
+2352ms ║Comparison (enum) off is (string) on = false (2ms)
+2374ms ║Comparison (time) 41301211 is_between (time) 1641907200000 … (time) 1641940920000 = true (12ms)
+2376ms ║Time restriction check passed
+2387ms ║Comparison (enum) off is (string) on = false (2ms)
+2396ms ║Comparison (string) Backyard flood light has been on for 2 hours. changes_to (string) ABC = false (1ms)
+2408ms ╚Piston successfully started (2408ms)
