I have a bunch of lights set to turn off at sunrise minus X minutes. I have one Caseta switch that refuses to cooperate. It will not turn off when the piston executes every day. The switch works fine because it turns on as programmed every night at sunset but it absolutely refuses to turn off when the piston runs in the morning. All other lights on the piston turn off as expected.
One thing that may be an issue: the icon in the ST app sometimes doesn’t reflect the actual state of the light. For example, if I open the ST app, sometimes it will show the light as OFF but when I actually walk downstairs and check, it shows as ON. When I click the icon in the app, it will change to ON, but no change to the light (they stay on) but if I click it again once the icon shows ON the icon will show OFF and the lights will turn off. So there is a mismatch sometimes between what shows in the app versus what state the light is actually in.
I don’t know if this has anything to do with the issue as to why the lights will not turn off at sunrise. I posted this same question in the Smartthings community forums but no one was able to answer my question, they just kept suggesting to unplug the hub and plug it back in.
For some further info: the hub is located less than 20 feet away from this Caseta switch. There isn’t a range issue because the lights will turn on/off with no problem when I use the ST app manually. I have removed and re-added this switch to my Caseta hub/ST hub multiple times and it won’t fix the issue.
Light should be turning off at sunrise minus X number of minutes.
Lights will not turn off as programmed.
10/27/2022, 6:59:59 AM +58ms
+1ms ╔Received event [Home].time = 1666868400000 with a delay of -942ms
+206ms ║RunTime Analysis CS > 17ms > PS > 141ms > PE > 47ms > CE
+208ms ║Runtime (38747 bytes) successfully initialized in 141ms (v0.3.114.20220203) (206ms)
+209ms ║╔Execution stage started
+252ms ║║Comparison (time) 25199273 happens_daily_at (time) 1666869900000 = false (1ms)
+254ms ║║Cancelling condition #2’s schedules…
+255ms ║║Condition #2 evaluated false (39ms)
+259ms ║║Cancelling statement #2’s schedules…
+265ms ║║Requesting time schedule wake up at Fri, Oct 28 2022 @ 6:55:00 AM EDT
+267ms ║║Cancelling condition #1’s schedules…
+268ms ║║Condition group #1 evaluated false (state changed) (53ms)
+274ms ║║Comparison (time) 25199329 happens_daily_at (time) 1666869900000 = true (0ms)
+275ms ║║Time restriction check passed
+277ms ║║Cancelling condition #6’s schedules…
+278ms ║║Condition #6 evaluated true (6ms)
+283ms ║║Cancelling statement #6’s schedules…
+288ms ║║Requesting time schedule wake up at Fri, Oct 28 2022 @ 7:00:00 AM EDT
+291ms ║║Cancelling condition #5’s schedules…
+291ms ║║Condition group #5 evaluated true (state changed) (20ms)
+294ms ║║Cancelling statement #7’s schedules…
+303ms ║║Skipped execution of physical command [Front Cutout 1].off([]) because it would make no change to the device. (5ms)
+304ms ║║Executed [Front Cutout 1].off (6ms)
+324ms ║║Skipped execution of physical command [Front Foyer Front Porch].off([]) because it would make no change to the device. (16ms)
+325ms ║║Executed [Front Foyer Front Porch].off (18ms)
+344ms ║║Executed physical command [Front Porch Front Door].off() (16ms)
+345ms ║║Executed [Front Porch Front Door].off (18ms)
+352ms ║║Skipped execution of physical command [Stairs 1].off([]) because it would make no change to the device. (5ms)
+353ms ║║Executed [Stairs 1].off (6ms)
+387ms ║║Skipped execution of physical command [Stairs 2].off([]) because it would make no change to the device. (31ms)
+388ms ║║Executed [Stairs 2].off (33ms)
+391ms ║╚Execution stage complete. (182ms)
+393ms ║Setting up scheduled job for Fri, Oct 28 2022 @ 6:55:00 AM EDT (in 86100s), with 1 more job pending
+398ms ╚Event processed successfully (398ms)
10/27/2022, 6:54:59 AM +62ms
+0ms ╔Received event [Home].time = 1666868100000 with a delay of -938ms
+55ms ║RunTime Analysis CS > 17ms > PS > 5ms > PE > 33ms > CE
+58ms ║Runtime (38742 bytes) successfully initialized in 5ms (v0.3.114.20220203) (57ms)
+59ms ║╔Execution stage started
+98ms ║║Comparison (time) 24899127 happens_daily_at (time) 1666869900000 = true (1ms)
+99ms ║║Time restriction check passed
+101ms ║║Condition #2 evaluated true (36ms)
+105ms ║║Cancelling statement #2’s schedules…
+110ms ║║Requesting time schedule wake up at Fri, Oct 28 2022 @ 6:55:00 AM EDT
+112ms ║║Condition group #1 evaluated true (state did not change) (48ms)
+114ms ║║Cancelling statement #3’s schedules…
+129ms ║║Skipped execution of physical command [Dining Room Chandelier].off([]) because it would make no change to the device. (5ms)
+130ms ║║Executed [Dining Room Chandelier].off (7ms)
+149ms ║║Skipped execution of physical command [Door Flood 1].off([]) because it would make no change to the device. (17ms)
+150ms ║║Executed [Door Flood 1].off (19ms)
+157ms ║║Skipped execution of physical command [Door Flood 2].off([]) because it would make no change to the device. (4ms)
+158ms ║║Executed [Door Flood 2].off (6ms)
+166ms ║║Skipped execution of physical command [Foyer Edison].off([]) because it would make no change to the device. (4ms)
+167ms ║║Executed [Foyer Edison].off (5ms)
+179ms ║║Skipped execution of physical command [Front Foyer Chandelier].off([]) because it would make no change to the device. (10ms)
+180ms ║║Executed [Front Foyer Chandelier].off (11ms)
+186ms ║║Skipped execution of physical command [Front Step Flood 1].off([]) because it would make no change to the device. (4ms)
+187ms ║║Executed [Front Step Flood 1].off (6ms)
+193ms ║║Skipped execution of physical command [Front Step Flood 2].off([]) because it would make no change to the device. (4ms)
+194ms ║║Executed [Front Step Flood 2].off (6ms)
+206ms ║║Skipped execution of physical command [Great Room Center].off([]) because it would make no change to the device. (9ms)
+207ms ║║Executed [Great Room Center].off (11ms)
+219ms ║║Skipped execution of physical command [Great Room Left].off([]) because it would make no change to the device. (10ms)
+220ms ║║Executed [Great Room Left].off (11ms)
+240ms ║║Skipped execution of physical command [Great Room Right].off([]) because it would make no change to the device. (18ms)
+241ms ║║Executed [Great Room Right].off (20ms)
+247ms ║║Skipped execution of physical command [Kitchen Side 1].off([]) because it would make no change to the device. (4ms)
+248ms ║║Executed [Kitchen Side 1].off (6ms)
+254ms ║║Skipped execution of physical command [Kitchen Side 2].off([]) because it would make no change to the device. (4ms)
+255ms ║║Executed [Kitchen Side 2].off (6ms)
+266ms ║║Skipped execution of physical command [Master Bedroom lamp].off([]) because it would make no change to the device. (9ms)
+267ms ║║Executed [Master Bedroom lamp].off (11ms)
+273ms ║║Skipped execution of physical command [Pond Side 1].off([]) because it would make no change to the device. (4ms)
+274ms ║║Executed [Pond Side 1].off (6ms)
+280ms ║║Skipped execution of physical command [Pond Side 2].off([]) because it would make no change to the device. (4ms)
+281ms ║║Executed [Pond Side 2].off (6ms)
+292ms ║║Skipped execution of physical command [Shelley Office].off([]) because it would make no change to the device. (8ms)
+293ms ║║Executed [Shelley Office].off (9ms)
+299ms ║║Skipped execution of physical command [Side Yard 1].off([]) because it would make no change to the device. (4ms)
+300ms ║║Executed [Side Yard 1].off (6ms)
+306ms ║║Skipped execution of physical command [Side Yard 2].off([]) because it would make no change to the device. (4ms)
+307ms ║║Executed [Side Yard 2].off (5ms)
+318ms ║║Skipped execution of physical command [Study Lights].off([]) because it would make no change to the device. (9ms)
+319ms ║║Executed [Study Lights].off (11ms)
+332ms ║║Skipped execution of physical command [Upstairs Hallway Spot Lights].off([]) because it would make no change to the device. (9ms)
+332ms ║║Executed [Upstairs Hallway Spot Lights].off (11ms)
+339ms ║║Comparison (time) 24899398 happens_daily_at (time) 1666869900000 = false (0ms)
+340ms ║║Condition #6 evaluated false (4ms)
+346ms ║║Cancelling statement #6’s schedules…
+351ms ║║Requesting time schedule wake up at Thu, Oct 27 2022 @ 7:00:00 AM EDT
+353ms ║║Condition group #5 evaluated false (state did not change) (18ms)
+356ms ║╚Execution stage complete. (298ms)
+358ms ║Setting up scheduled job for Thu, Oct 27 2022 @ 7:00:00 AM EDT (in 300s), with 1 more job pending
+363ms ╚Event processed successfully (363ms)
