Well… here was my first attempt. I set the motion sensor off and the lights went on (as predicted). After about 3 mintues, the lights went off. About 15 seconds after the light went off, I went back outside and set the motion sensor off again… however, the lights remained off. I attempted again, and it worked as predicted. Thoughts?
Here is the log:
1/16/2018, 4:42:56 PM +80ms +1ms ╔Received event [Front Doorbell].motion = inactive with a delay of 49ms +106ms ║RunTime Analysis CS > 10ms > PS > 24ms > PE > 72ms > CE +108ms ║Runtime (39276 bytes) successfully initialized in 24ms (v0.2.101.20171227) (107ms) +109ms ║╔Execution stage started +117ms ║║Comparison (enum) inactive is (string) active = false (1ms) +118ms ║║Cancelling condition #9's schedules... +119ms ║║Condition #9 evaluated false (5ms) +120ms ║║Cancelling condition #1's schedules... +120ms ║║Condition group #1 evaluated false (state changed) (7ms) +129ms ║║Comparison (enum) on is (string) on = true (2ms) +130ms ║║Cancelling condition #12's schedules... +131ms ║║Condition #12 evaluated true (9ms) +132ms ║║Cancelling condition #10's schedules... +132ms ║║Condition group #10 evaluated true (state changed) (10ms) +134ms ║║Cancelling statement #2's schedules... +138ms ║║Executed virtual command [Garage Lights, Porch Light].wait (1ms) +139ms ║║Requesting a wake up for Tue, Jan 16 2018 @ 4:45:56 PM EST (in 180.0s) +143ms ║╚Execution stage complete. (34ms) +145ms ║Setting up scheduled job for Tue, Jan 16 2018 @ 4:45:56 PM EST (in 179.995s) +151ms ╚Event processed successfully (151ms) 1/16/2018, 4:42:27 PM +717ms +2ms ╔Received event [Porch Light].switch = on with a delay of 101ms +140ms ║RunTime Analysis CS > 20ms > PS > 42ms > PE > 77ms > CE +142ms ║Runtime (39268 bytes) successfully initialized in 42ms (v0.2.101.20171227) (140ms) +143ms ║╔Execution stage started +156ms ║║Comparison (enum) active is (string) active = true (1ms) +157ms ║║Condition #9 evaluated true (9ms) +158ms ║║Condition group #1 evaluated true (state did not change) (11ms) +163ms ║║Comparison (boolean) false is (boolean) true = false (1ms) +164ms ║║Condition #16 evaluated false (4ms) +165ms ║║Condition group #13 evaluated false (state did not change) (5ms) +206ms ║║Comparison (time) 60147884 is_between (time) 1516140120000 .. (time) 1516105380000 = true (8ms) +207ms ║║Time restriction check passed +208ms ║║Condition #8 evaluated true (41ms) +209ms ║║Condition group #5 evaluated true (state did not change) (42ms) +210ms ║║Cancelling statement #5's schedules... +244ms ║║Executed physical command [Garage Lights].on() (30ms) +245ms ║║Executed [Garage Lights].on (32ms) +249ms ║║Skipped execution of physical command [Porch Light].on([]) because it would make no change to the device. (0ms) +249ms ║║Executed [Porch Light].on (2ms) +267ms ║║Executed physical command [Garage Lights].setLevel([100]) (15ms) +268ms ║║Executed [Garage Lights].setLevel (16ms) +423ms ║║Executed physical command [Porch Light].setLevel([100]) (153ms) +423ms ║║Executed [Porch Light].setLevel (155ms) +426ms ║╚Execution stage complete. (283ms) +427ms ╚Event processed successfully (427ms) 1/16/2018, 4:42:26 PM +701ms +0ms ╔Received event [Front Doorbell].motion = active with a delay of 43ms +103ms ║RunTime Analysis CS > 11ms > PS > 25ms > PE > 67ms > CE +105ms ║Runtime (39278 bytes) successfully initialized in 25ms (v0.2.101.20171227) (104ms) +106ms ║╔Execution stage started +114ms ║║Comparison (enum) active is (string) active = true (1ms) +116ms ║║Cancelling condition #9's schedules... +117ms ║║Condition #9 evaluated true (5ms) +117ms ║║Cancelling condition #1's schedules... +118ms ║║Condition group #1 evaluated true (state changed) (8ms) +124ms ║║Comparison (boolean) false is (boolean) true = false (1ms) +125ms ║║Cancelling condition #16's schedules... +126ms ║║Condition #16 evaluated false (5ms) +126ms ║║Cancelling condition #13's schedules... +127ms ║║Condition group #13 evaluated false (state changed) (7ms) +303ms ║║Comparison (time) 60146831 is_between (time) 1516140120000 .. (time) 1516105380000 = true (7ms) +304ms ║║Time restriction check passed +305ms ║║Condition #8 evaluated true (176ms) +306ms ║║Condition group #5 evaluated true (state did not change) (177ms) +307ms ║║Cancelling statement #5's schedules... +331ms ║║Executed physical command [Garage Lights].on() (21ms) +332ms ║║Executed [Garage Lights].on (23ms) +350ms ║║Executed physical command [Porch Light].on() (16ms) +351ms ║║Executed [Porch Light].on (18ms) +369ms ║║Executed physical command [Garage Lights].setLevel([100]) (15ms) +370ms ║║Executed [Garage Lights].setLevel (16ms) +384ms ║║Executed physical command [Porch Light].setLevel([100]) (13ms) +385ms ║║Executed [Porch Light].setLevel (15ms) +387ms ║╚Execution stage complete. (281ms) +389ms ╚Event processed successfully (388ms) 1/16/2018, 4:37:23 PM +196ms +1ms ╔Received event [Front Doorbell].motion = inactive with a delay of 68ms +109ms ║RunTime Analysis CS > 15ms > PS > 25ms > PE > 68ms > CE +111ms ║Runtime (39273 bytes) successfully initialized in 25ms (v0.2.101.20171227) (109ms) +112ms ║╔Execution stage started +120ms ║║Comparison (enum) inactive is (string) active = false (1ms) +122ms ║║Cancelling condition #9's schedules... +123ms ║║Condition #9 evaluated false (5ms) +123ms ║║Cancelling condition #1's schedules... +124ms ║║Condition group #1 evaluated false (state changed) (8ms) +133ms ║║Comparison (enum) off is (string) on = false (1ms) +134ms ║║Condition #12 evaluated false (8ms) +135ms ║║Condition group #10 evaluated false (state did not change) (9ms) +138ms ║╚Execution stage complete. (25ms) +139ms ╚Event processed successfully (138ms) 1/16/2018, 4:36:53 PM +855ms +2ms ╔Received event [Front Doorbell].motion = active with a delay of 100ms +142ms ║RunTime Analysis CS > 20ms > PS > 46ms > PE > 75ms > CE +144ms ║Runtime (39281 bytes) successfully initialized in 46ms (v0.2.101.20171227) (141ms) +145ms ║╔Execution stage started +154ms ║║Comparison (enum) active is (string) active = true (2ms) +155ms ║║Cancelling condition #9's schedules... +156ms ║║Condition #9 evaluated true (6ms) +157ms ║║Cancelling condition #1's schedules... +158ms ║║Condition group #1 evaluated true (state changed) (7ms) +163ms ║║Comparison (boolean) true is (boolean) true = true (2ms) +164ms ║║Cancelling condition #16's schedules... +165ms ║║Condition #16 evaluated true (5ms) +166ms ║║Cancelling condition #13's schedules... +166ms ║║Condition group #13 evaluated true (state changed) (7ms) +169ms ║║Cancelling statement #14's schedules... +174ms ║║Executed virtual command setVariable (3ms) +177ms ║╚Execution stage complete. (32ms) +178ms ╚Event processed successfully (178ms) 1/16/2018, 4:36:32 PM +407ms +0ms ╔Received event [Home].time = 1516138593668 with a delay of -1262ms +170ms ║RunTime Analysis CS > 42ms > PS > 37ms > PE > 92ms > CE +173ms ║Runtime (39278 bytes) successfully initialized in 37ms (v0.2.101.20171227) (156ms) +175ms ║╔Execution stage started +176ms ║╚Execution stage complete. (2ms) +179ms ╚Event processed successfully (179ms) 1/16/2018, 4:36:27 PM +187ms +1ms ╔Received event [Porch Light].switch = off with a delay of 88ms +114ms ║RunTime Analysis CS > 15ms > PS > 27ms > PE > 72ms > CE +116ms ║Runtime (39271 bytes) successfully initialized in 27ms (v0.2.101.20171227) (115ms) +117ms ║╔Execution stage started +129ms ║║Comparison (enum) inactive is (string) active = false (2ms) +130ms ║║Condition #9 evaluated false (8ms) +131ms ║║Condition group #1 evaluated false (state did not change) (9ms) +137ms ║║Comparison (enum) off is (string) on = false (1ms) +138ms ║║Cancelling condition #12's schedules... +139ms ║║Condition #12 evaluated false (6ms) +140ms ║║Cancelling condition #10's schedules... +141ms ║║Condition group #10 evaluated false (state changed) (8ms) +143ms ║╚Execution stage complete. (26ms) +144ms ╚Event processed successfully (144ms) 1/16/2018, 4:36:26 PM +362ms +1ms ╔Received event [Home].time = 1516138587459 with a delay of -1097ms +163ms ║RunTime Analysis CS > 20ms > PS > 46ms > PE > 96ms > CE +165ms ║Runtime (39276 bytes) successfully initialized in 46ms (v0.2.101.20171227) (163ms) +166ms ║╔Execution stage started +271ms ║║Executed physical command [Garage Lights].off() (82ms) +272ms ║║Executed [Garage Lights].off (85ms) +293ms ║║Executed physical command [Porch Light].off() (18ms) +294ms ║║Executed [Porch Light].off (20ms) +300ms ║║Executed virtual command [Garage Lights, Porch Light].setVariable (2ms) +304ms ║║Executed virtual command [Garage Lights, Porch Light].wait (0ms) +305ms ║║Requesting a wake up for Tue, Jan 16 2018 @ 4:36:33 PM EST (in 7.0s) +312ms ║╚Execution stage complete. (146ms) +314ms ║Setting up scheduled job for Tue, Jan 16 2018 @ 4:36:33 PM EST (in 6.992s) +322ms ╚Event processed successfully (322ms) 1/16/2018, 4:33:27 PM +284ms +1ms ╔Received event [Front Doorbell].motion = inactive with a delay of 88ms +139ms ║RunTime Analysis CS > 21ms > PS > 44ms > PE > 74ms > CE +141ms ║Runtime (39276 bytes) successfully initialized in 44ms (v0.2.101.20171227) (139ms) +142ms ║╔Execution stage started +150ms ║║Comparison (enum) inactive is (string) active = false (1ms) +152ms ║║Cancelling condition #9's schedules... +153ms ║║Condition #9 evaluated false (5ms) +154ms ║║Cancelling condition #1's schedules... +154ms ║║Condition group #1 evaluated false (state changed) (8ms) +163ms ║║Comparison (enum) on is (string) on = true (2ms) +164ms ║║Cancelling condition #12's schedules... +165ms ║║Condition #12 evaluated true (9ms) +166ms ║║Cancelling condition #10's schedules... +166ms ║║Condition group #10 evaluated true (state changed) (10ms) +169ms ║║Cancelling statement #2's schedules... +173ms ║║Executed virtual command [Garage Lights, Porch Light].wait (0ms) +174ms ║║Requesting a wake up for Tue, Jan 16 2018 @ 4:36:27 PM EST (in 180.0s) +179ms ║╚Execution stage complete. (37ms) +181ms ║Setting up scheduled job for Tue, Jan 16 2018 @ 4:36:27 PM EST (in 179.995s) +186ms ╚Event processed successfully (186ms) 1/16/2018, 4:33:00 PM +142ms +2ms ╔Received event [Porch Light].switch = on with a delay of 104ms +141ms ║RunTime Analysis CS > 22ms > PS > 41ms > PE > 78ms > CE +144ms ║Runtime (39268 bytes) successfully initialized in 41ms (v0.2.101.20171227) (142ms) +145ms ║╔Execution stage started +156ms ║║Comparison (enum) active is (string) active = true (1ms) +157ms ║║Condition #9 evaluated true (8ms) +158ms ║║Condition group #1 evaluated true (state did not change) (9ms) +163ms ║║Comparison (boolean) false is (boolean) true = false (1ms) +164ms ║║Condition #16 evaluated false (4ms) +165ms ║║Condition group #13 evaluated false (state did not change) (5ms) +205ms ║║Comparison (time) 59580309 is_between (time) 1516140120000 .. (time) 1516105380000 = true (7ms) +206ms ║║Time restriction check passed +207ms ║║Condition #8 evaluated true (40ms) +208ms ║║Condition group #5 evaluated true (state did not change) (41ms) +209ms ║║Cancelling statement #5's schedules... +246ms ║║Executed physical command [Garage Lights].on() (34ms) +247ms ║║Executed [Garage Lights].on (36ms) +250ms ║║Skipped execution of physical command [Porch Light].on([]) because it would make no change to the device. (1ms) +250ms ║║Executed [Porch Light].on (1ms) +523ms ║║Executed physical command [Garage Lights].setLevel([100]) (270ms) +524ms ║║Executed [Garage Lights].setLevel (271ms) +544ms ║║Executed physical command [Porch Light].setLevel([100]) (19ms) +544ms ║║Executed [Porch Light].setLevel (20ms) +547ms ║╚Execution stage complete. (403ms) +548ms ╚Event processed successfully (548ms) 1/16/2018, 4:32:57 PM +782ms +2ms ╔Received event [Front Doorbell].motion = active with a delay of 98ms +144ms ║RunTime Analysis CS > 19ms > PS > 53ms > PE > 71ms > CE +146ms ║Runtime (39283 bytes) successfully initialized in 53ms (v0.2.101.20171227) (144ms) +147ms ║╔Execution stage started +155ms ║║Comparison (enum) active is (string) active = true (1ms) +157ms ║║Cancelling condition #9's schedules... +157ms ║║Condition #9 evaluated true (5ms) +158ms ║║Cancelling condition #1's schedules... +159ms ║║Condition group #1 evaluated true (state changed) (8ms) +164ms ║║Comparison (boolean) false is (boolean) true = false (1ms) +165ms ║║Condition #16 evaluated false (4ms) +166ms ║║Condition group #13 evaluated false (state did not change) (5ms) +205ms ║║Comparison (time) 59577950 is_between (time) 1516140120000 .. (time) 1516105380000 = true (8ms) +206ms ║║Time restriction check passed +207ms ║║Cancelling condition #8's schedules... +208ms ║║Condition #8 evaluated true (40ms) +209ms ║║Cancelling condition #5's schedules... +209ms ║║Condition group #5 evaluated true (state changed) (41ms) +210ms ║║Cancelling statement #5's schedules... +233ms ║║Executed physical command [Garage Lights].on() (19ms) +234ms ║║Executed [Garage Lights].on (21ms) +255ms ║║Executed physical command [Porch Light].on() (19ms) +256ms ║║Executed [Porch Light].on (20ms) +272ms ║║Executed physical command [Garage Lights].setLevel([100]) (13ms) +273ms ║║Executed [Garage Lights].setLevel (13ms) +286ms ║║Executed physical command [Porch Light].setLevel([100]) (12ms) +287ms ║║Executed [Porch Light].setLevel (14ms) +290ms ║╚Execution stage complete. (143ms) +291ms ╚Event processed successfully (291ms)
