Okay, so I messed with it a bit and I’m still having issues (piston and log below). I gave up on the physical interaction as it just wasn’t working, so I need some help there. But before that, I need to get the basic piston straight.
The light turns on when the door opens. When closed, the delay is fine, but the warning “flash” doesn’t happen.
If there is any physical interaction with the switch, everything goes south. Doesn’t turn on when opened or off when closed unless I wait a minute or two. Note, that I removed the physical switch section I mentioned above so this wasn’t a cause.
Below is the revised Piston. Note that minutes are replaced with seconds and seconds are replaced with milliseconds for testing purposes.
> 4/19/2022, 8:06:59 PM +45ms
> +0ms ╔Received event [Home].time = 1650424020978 with a delay of -1934ms
> +50ms ║RunTime Analysis CS > 17ms > PS > 5ms > PE > 29ms > CE
> +52ms ║Runtime (39064 bytes) successfully initialized in 5ms (v0.3.114.20220203) (51ms)
> +53ms ║╔Execution stage started
> +173ms ║║Executed physical command [Garage Side Door].off() (99ms)
> +179ms ║║Executed physical command [Garage Side Door].on([delay: 300]) (6ms)
> +185ms ║║Executed physical command [Garage Side Door].on([delay: 699]) (5ms)
> +186ms ║║Executed virtual command [Garage Side Door].flash (116ms)
> +188ms ║║Waiting for 700ms
> +892ms ║║Executed virtual command [Garage Side Door].wait (1ms)
> +893ms ║║Waiting for 2000ms
> +2899ms ║║Skipped execution of physical command [Garage Side Door].off([]) because it would make no change to the device. (4ms)
> +2900ms ║║Executed [Garage Side Door].off (6ms)
> +2902ms ║╚Execution stage complete. (2849ms)
> +2909ms ╚Event processed successfully (2910ms)
> 4/19/2022, 8:06:50 PM +880ms
> +1ms ╔Received event [Garage Side Door Sensor].contact = closed with a delay of 90ms
> +57ms ║RunTime Analysis CS > 15ms > PS > 5ms > PE > 37ms > CE
> +60ms ║Runtime (39078 bytes) successfully initialized in 5ms (v0.3.114.20220203) (57ms)
> +60ms ║╔Execution stage started
> +68ms ║║Comparison (enum) closed changes_away_from (string) closed = false (0ms)
> +69ms ║║Cancelling condition #3's schedules...
> +70ms ║║Condition #3 evaluated false (5ms)
> +71ms ║║Condition group #1 evaluated false (state did not change) (7ms)
> +77ms ║║Comparison (enum) closed changes_away_from (string) open = true (1ms)
> +78ms ║║Cancelling condition #55's schedules...
> +79ms ║║Condition #55 evaluated true (5ms)
> +88ms ║║Comparison (enum) on is (string) on = true (2ms)
> +89ms ║║Condition #56 evaluated true (9ms)
> +90ms ║║Cancelling condition #54's schedules...
> +91ms ║║Condition group #54 evaluated true (state changed) (18ms)
> +93ms ║║Cancelling statement #57's schedules...
> +97ms ║║Executed virtual command [Garage Side Door].wait (0ms)
> +98ms ║║Requesting a wake up for Tue, Apr 19 2022 @ 8:07:00 PM PDT (in 10.0s)
> +102ms ║╚Execution stage complete. (42ms)
> +103ms ║Setting up scheduled job for Tue, Apr 19 2022 @ 8:07:00 PM PDT (in 9s)
> +111ms ╚Event processed successfully (111ms)
