Piston trigger for sunset ran at 12:46 PM
This piston has been running normal at sunset for several months
Piston did not run at sunset. It ran in the middle of the day. Not sure if this is just a fluke or a mis-configuration.
3/19/2020, 12:46:59 PM +77ms
+1ms ╔Received event [Home].time = 1584636420000 with a delay of -923ms
+135ms ║RunTime Analysis CS > 58ms > PS > 44ms > PE > 32ms > CE
+137ms ║Runtime (37715 bytes) successfully initialized in 44ms (v0.3.110.20191009) (135ms)
+138ms ║╔Execution stage started
+170ms ║║Comparison (time) 46019221 happens_daily_at (time) 1584636420000 = true (0ms)
+171ms ║║Time restriction check passed
+172ms ║║Condition #2 evaluated true (28ms)
+177ms ║║Cancelling statement #2’s schedules…
+182ms ║║Requesting time schedule wake up at Fri, Mar 20 2020 @ 12:47:00 PM EDT
+184ms ║║Condition group #1 evaluated true (state did not change) (41ms)
+186ms ║║Cancelling statement #3’s schedules…
+204ms ║║Executed physical command [Garage Front Light].on() (12ms)
+205ms ║║Executed [Garage Front Light].on (15ms)
+219ms ║║Executed physical command [Garage Side Light].on() (11ms)
+220ms ║║Executed [Garage Side Light].on (13ms)
+233ms ║║Executed physical command [House Front Light].on() (11ms)
+235ms ║║Executed [House Front Light].on (13ms)
+381ms ║║Executed virtual command [Garage Front Light, Garage Side Light, House Front Light].sendSMSNotification (138ms)
+405ms ║╚Execution stage complete. (267ms)
+407ms ║Setting up scheduled job for Fri, Mar 20 2020 @ 4:00:00 AM EDT (in 54780.517s), with 1 more job pending
+414ms ╚Event processed successfully (414ms)
3/19/2020, 3:59:59 AM +79ms
+1ms ╔Received event [Home].time = 1584604800000 with a delay of -921ms
+118ms ║RunTime Analysis CS > 34ms > PS > 43ms > PE > 40ms > CE
+121ms ║Runtime (37715 bytes) successfully initialized in 43ms (v0.3.110.20191009) (117ms)
+122ms ║╔Execution stage started
+144ms ║║Cancelling statement #2’s schedules…
+181ms ║║Requesting time schedule wake up at Thu, Mar 19 2020 @ 12:47:00 PM EDT
+225ms ║╚Execution stage complete. (104ms)
+227ms ║Setting up scheduled job for Thu, Mar 19 2020 @ 12:47:00 PM EDT (in 31620.694s), with 1 more job pending
+234ms ╚Event processed successfully (233ms)
3/18/2020, 6:45:59 PM +77ms
+1ms ╔Received event [Home].time = 1584571560000 with a delay of -923ms
+223ms ║RunTime Analysis CS > 79ms > PS > 112ms > PE > 32ms > CE
+226ms ║Runtime (37717 bytes) successfully initialized in 112ms (v0.3.110.20191009) (223ms)
+226ms ║╔Execution stage started
+262ms ║║Comparison (time) 67559309 happens_daily_at (time) 1584571560000 = true (1ms)
+263ms ║║Time restriction check passed
+264ms ║║Condition #2 evaluated true (32ms)
+269ms ║║Cancelling statement #2’s schedules…
+273ms ║║Requesting time schedule wake up at Thu, Mar 19 2020 @ 6:46:00 PM EDT
+276ms ║║Condition group #1 evaluated true (state did not change) (44ms)
+278ms ║║Cancelling statement #3’s schedules…
+466ms ║║Executed physical command [Garage Front Light].on() (182ms)
+467ms ║║Executed [Garage Front Light].on (184ms)
+482ms ║║Executed physical command [Garage Side Light].on() (12ms)
+482ms ║║Executed [Garage Side Light].on (14ms)
+496ms ║║Executed physical command [House Front Light].on() (12ms)
+497ms ║║Executed [House Front Light].on (14ms)
+509ms ║║Executed virtual command [Garage Front Light, Garage Side Light, House Front Light].sendSMSNotification (7ms)
+536ms ║╚Execution stage complete. (310ms)
+538ms ║Setting up scheduled job for Thu, Mar 19 2020 @ 4:00:00 AM EDT (in 33240.385s), with 1 more job pending
+545ms ╚Event processed successfully (544ms)
