Switch is coming on randomly
Using a motion sensor to trigger on and off
It seems to work for the most part, some delay in on events and seemed to randomly not turn off, but looking at the logs it actually seems to turn itself on when no motion is happening
5/23/2022, 9:54:50 PM +768ms
+1ms ╔Received event [Garage Lights].switch = off with a delay of 55ms
+149ms ║off
+153ms ╚Event processed successfully (153ms)
+87ms ║off
+91ms ╚Event processed successfully (91ms)
5/23/2022, 9:02:15 PM +454ms
+1ms ╔Received event [Garage Lights].switch = on with a delay of 66ms
+95ms ║on
+99ms ╚Event processed successfully (99ms)
5/23/2022, 8:56:59 PM +50ms
+1ms ╔Received event [Ventura].time = 1653364620082 with a delay of -1032ms
+108ms ╚Event processed successfully (108ms)
5/23/2022, 8:54:59 PM +984ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 51ms
+103ms ║Setting up scheduled job for Mon, May 23 2022 @ 8:57:00 PM PDT (in 119s)
5/23/2022, 8:54:48 PM +91ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 56ms
+121ms ╚Event processed successfully (121ms)
5/23/2022, 7:47:11 PM +548ms
+1ms ╔Received event [Garage Lights].switch = off with a delay of 61ms
+10085ms ║Piston waited at a semaphore for 10017ms
+10105ms ╚Event processed successfully (10105ms)
5/23/2022, 7:47:11 PM +543ms
+1ms ╔Received event [Garage Lights].switch = off with a delay of 56ms
+84ms ║off
+89ms ╚Event processed successfully (88ms)
5/23/2022, 7:47:11 PM +50ms
+0ms ╔Received event [Ventura].time = 1653360432572 with a delay of -1523ms
5/23/2022, 7:45:12 PM +489ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 52ms
+88ms ║Setting up scheduled job for Mon, May 23 2022 @ 7:47:12 PM PDT (in 119s)
+95ms ╚Event processed successfully (95ms)
5/23/2022, 7:45:00 PM +550ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 58ms
+94ms ╚Event processed successfully (94ms)
5/23/2022, 7:44:52 PM +158ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 54ms
+86ms ╚Event processed successfully (86ms)
5/23/2022, 7:44:42 PM +747ms
5/23/2022, 7:44:32 PM +970ms
+2ms ╔Received event [Motion Garage].motion = active with a delay of 54ms
+109ms ╚Event processed successfully (109ms)
5/23/2022, 7:44:24 PM +831ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 54ms
+100ms ║Setting up scheduled job for Mon, May 23 2022 @ 7:46:24 PM PDT (in 119s)
+106ms ╚Event processed successfully (106ms)
5/23/2022, 7:44:13 PM +485ms
+1ms ╔Received event [Garage Lights].switch = on with a delay of 64ms
+10089ms ║Piston waited at a semaphore for 10017ms
+10109ms ╚Event processed successfully (10108ms)
5/23/2022, 7:44:13 PM +481ms
+1ms ╔Received event [Garage Lights].switch = on with a delay of 60ms
+95ms ║on
5/23/2022, 7:44:12 PM +925ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 51ms
+128ms ╚Event processed successfully (128ms)
5/23/2022, 7:33:16 PM +484ms
+1ms ╔Received event [Garage Lights].switch = off with a delay of 63ms
+10101ms ║Piston waited at a semaphore for 10019ms
+10119ms ╚Event processed successfully (10119ms)
5/23/2022, 7:33:16 PM +483ms
+103ms ║off
5/23/2022, 7:22:35 PM +58ms
+1ms ╔Received event [Ventura].time = 1653358956315 with a delay of -1257ms
5/23/2022, 7:20:36 PM +230ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 53ms
+90ms ║Setting up scheduled job for Mon, May 23 2022 @ 7:22:36 PM PDT (in 119s)
+97ms ╚Event processed successfully (97ms)
5/23/2022, 7:20:24 PM +304ms
+2ms ╔Received event [Motion Garage].motion = active with a delay of 49ms
+90ms ╚Event processed successfully (90ms)
5/23/2022, 7:20:11 PM +259ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 53ms
+111ms ╚Event processed successfully (110ms)
5/23/2022, 7:19:57 PM +602ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 47ms
+83ms ║Setting up scheduled job for Mon, May 23 2022 @ 7:21:57 PM PDT (in 119s)
5/23/2022, 7:19:45 PM +667ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 47ms
5/23/2022, 7:19:37 PM +806ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 52ms
5/23/2022, 7:19:23 PM +173ms
+100ms ╚Event processed successfully (100ms)
5/23/2022, 7:19:15 PM +337ms
+2ms ╔Received event [Motion Garage].motion = active with a delay of 57ms
+94ms ╚Event processed successfully (93ms)
5/23/2022, 7:19:07 PM +169ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 55ms
+191ms ╚Event processed successfully (191ms)
5/23/2022, 7:18:57 PM +448ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 55ms
+96ms ║Setting up scheduled job for Mon, May 23 2022 @ 7:20:57 PM PDT (in 119s)
+102ms ╚Event processed successfully (102ms)
5/23/2022, 7:18:45 PM +484ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 50ms
+86ms ╚Event processed successfully (85ms)
5/23/2022, 7:18:35 PM +833ms
+88ms ╚Event processed successfully (87ms)
5/23/2022, 7:18:27 PM +991ms
+96ms ╚Event processed successfully (96ms)
5/23/2022, 7:18:15 PM +189ms
+1ms ╔Received event [Garage Lights].switch = on with a delay of 67ms
+98ms ║on
5/23/2022, 7:18:14 PM +623ms
+0ms ╔Received event [Motion Garage].motion = active with a delay of 53ms
5/23/2022, 4:45:22 PM +632ms
+1ms ╔Received event [Garage Lights].switch = off with a delay of 67ms
+10106ms ║Piston waited at a semaphore for 10033ms
+10127ms ╚Event processed successfully (10127ms)
5/23/2022, 4:45:22 PM +623ms
+1ms ╔Received event [Garage Lights].switch = off with a delay of 58ms
+85ms ║off
+89ms ╚Event processed successfully (89ms)
5/23/2022, 4:45:22 PM +63ms
+0ms ╔Received event [Ventura].time = 1653349523539 with a delay of -1477ms
+123ms ╚Event processed successfully (124ms)
5/23/2022, 4:43:23 PM +459ms
+84ms ║Setting up scheduled job for Mon, May 23 2022 @ 4:45:23 PM PDT (in 119s)
5/23/2022, 4:43:11 PM +232ms
+1ms ╔Received event [Garage Lights].switch = on with a delay of 63ms
+91ms ║on
+96ms ╚Event processed successfully (95ms)
5/23/2022, 4:43:10 PM +668ms
5/23/2022, 4:35:47 PM +606ms
+1ms ╔Received event [Garage Lights].switch = off with a delay of 62ms
+10102ms ║Piston waited at a semaphore for 10021ms
+10121ms ╚Event processed successfully (10121ms)
5/23/2022, 4:35:47 PM +605ms
+94ms ║off
5/23/2022, 4:35:47 PM +51ms
+0ms ╔Received event [Ventura].time = 1653348948303 with a delay of -1253ms
+117ms ╚Event processed successfully (117ms)
5/23/2022, 4:33:48 PM +223ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 48ms
+84ms ║Setting up scheduled job for Mon, May 23 2022 @ 4:35:48 PM PDT (in 119s)
+92ms ╚Event processed successfully (92ms)
5/23/2022, 4:33:36 PM +8ms
+105ms ╚Event processed successfully (105ms)
5/23/2022, 4:33:27 PM +860ms
+98ms ║Setting up scheduled job for Mon, May 23 2022 @ 4:35:27 PM PDT (in 119s)
5/23/2022, 4:33:15 PM +615ms
+0ms ╔Received event [Motion Garage].motion = active with a delay of 46ms
+96ms ╚Event processed successfully (97ms)
5/23/2022, 4:33:07 PM +168ms
+110ms ║on
+116ms ╚Event processed successfully (116ms)
5/23/2022, 4:33:06 PM +585ms
+126ms ╚Event processed successfully (127ms)
5/23/2022, 4:26:59 PM +635ms
+1ms ╔Received event [Garage Lights].switch = off with a delay of 60ms
+91ms ║off
+95ms ╚Event processed successfully (94ms)
5/23/2022, 4:26:59 PM +49ms
+0ms ╔Received event [Ventura].time = 1653348420701 with a delay of -1653ms
+129ms ╚Event processed successfully (130ms)
5/23/2022, 4:25:00 PM +617ms
+89ms ║Setting up scheduled job for Mon, May 23 2022 @ 4:27:00 PM PDT (in 119s)
5/23/2022, 4:24:48 PM +674ms
+1ms ╔Received event [Motion Garage].motion = active with a delay of 48ms
+77ms ╚Event processed successfully (76ms)
5/23/2022, 4:24:40 PM +824ms
+132ms ╚Event processed successfully (133ms)
5/23/2022, 4:24:31 PM +33ms
5/23/2022, 4:24:23 PM +499ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 46ms
+95ms ║Setting up scheduled job for Mon, May 23 2022 @ 4:26:23 PM PDT (in 119s)
+101ms ╚Event processed successfully (101ms)
5/23/2022, 4:24:12 PM +774ms
5/23/2022, 3:59:29 PM +35ms
+1ms ╔Received event [Garage Lights].switch = on with a delay of 68ms
+10147ms ║Piston waited at a semaphore for 10069ms
+10166ms ╚Event processed successfully (10166ms)
5/23/2022, 3:59:29 PM +28ms
+89ms ║on
+93ms ╚Event processed successfully (93ms)
5/23/2022, 3:46:47 PM +48ms
+0ms ╔Received event [Ventura].time = 1653346008013 with a delay of -965ms
5/23/2022, 3:44:47 PM +920ms
+1ms ╔Received event [Motion Garage].motion = inactive with a delay of 62ms
+98ms ║Setting up scheduled job for Mon, May 23 2022 @ 3:46:48 PM PDT (in 119s)
5/23/2022, 3:44:38 PM +985ms
+2ms ╔Received event [Motion Garage].motion = active with a delay of 58ms
5/23/2022, 3:44:28 PM +87ms
+0ms ╔Received event [Motion Garage].motion = active with a delay of 43ms
+106ms ╚Event processed successfully (105ms)
5/23/2022, 3:44:27 PM +351ms
+88ms ║off
+97ms ╚Event processed successfully (96ms)
5/23/2022, 3:42:54 PM +157ms
+2ms ╔Received event [Motion Garage].motion = inactive with a delay of 49ms
+87ms ║Setting up scheduled job for Mon, May 23 2022 @ 3:44:54 PM PDT (in 119s)
5/23/2022, 3:42:42 PM +281ms
+98ms ╚Event processed successfully (98ms)
5/23/2022, 3:31:38 PM +55ms
+1ms ╔Received event [Ventura].time = 1653345099039 with a delay of -984ms
+125ms ╚Event processed successfully (125ms)
5/23/2022, 3:29:38 PM +952ms
+2ms ╔Received event [Motion Garage].motion = inactive with a delay of 52ms
+92ms ║Setting up scheduled job for Mon, May 23 2022 @ 3:31:39 PM PDT (in 119s)
5/23/2022, 3:29:25 PM +586ms
+10224ms ║Piston waited at a semaphore for 10152ms
+10243ms ╚Event processed successfully (10243ms)
5/23/2022, 3:29:25 PM +579ms
+1ms ╔Received event [Garage Lights].switch = on with a delay of 59ms
+83ms ║on
+87ms ╚Event processed successfully (87ms)
5/23/2022, 3:29:25 PM +2ms
