I have a switchbot contact sensor that on the switchbot app can obviously be either open or closed but also, with the use of either a button or built in motion sensor can tell if you’re exiting or entering the room. I can’t figure out how to have webcore detect if the device is set to exit or enter.
When I leave the house and press the button on the contact sensor to set it to “exit”, I want to capture that so that I can change the ST Security armed to “armed away” and then switch it “disarmed” when I come back home.
I’m able to make for when the contact sensor is “open” or “closed” but I can’t figure out an “exit” or “enter”.
First time posting on here so I apologize if my format isn’t fully correct or if I’m posting this on the wrong category. In the screenshot posted above, I am using the status of the sensor because if I use “contact”, all I get is open or closed. Any help would be greatly appreciated!
