I have 2 different light strips that I would like to sync to the same color loop. Is this possible? I seen and tried pistons that will match color, but they won’t change when the “master” fades into another color.
Thanks
Sync RGB Light Strips to the same color loop?
For all practical purposes, once a fade begins, it is impossible to stop it.
(the slightly different commands just keep on pushing thru)
Trying to get another bulb to match a bulb (that is constantly changing) sounds like a mountain of trouble. BulbA will already be on a new color by the time BulbB syncs to the previous color.
I highly encourage you to re-think your goals. It will put a lot of stress on your SmartHome, and the results will not look professional.
Instead of trying to sync them, I might consider letting a piston simultaneously control both lights at the same time.
There is also a custom app that allows you to group lights together.
And there is smart lights which allows you to mirror light behavior between set lights.
This is what I was starting to think, to much of a headache. It is nothing important that I am trying to do, I was just playing around. They each have their own purpose and pistons, I just thought about syncing them up during their “idle” time.
If I do
with RGB1 and RGB2
do loop()
They start out with different colors and it looks silly. But like I said, I’m just playing around.
Thanks guys
You can make the first command:
With RGB1 & RGB 2
Set color to purple
and then start a fade or loop.
(although I usually avoid using fades, so I have not tested this)
lol they all started the same color, but quickly went their own directions. Like you said, they never stay in sync. Oh well.
Great you’re learning webcore but just so you know there is a smartapp available directly from the mobile app (new and old) that does exactly this. It’s called “Color Coordinator” and you find it by simply clicking SmartApps->Lights and Switches - > color coordinator
