I have a piston of the following format.
IF A changes to ON then Do something.X
IF B changes to ON then Do Something Y
It works 90% of the time. But every once in awhile it doesn’t function properly. I was able to determine that if A and B occur at the same time is when it doesn’t work. A only gets evaluated, B doesn’t.
If I change those to Async will that solve that problem? I read the WIKI but still not sure.
