Trying to get my kids to close the door behind them.
The piston determines if the house is wide open to the elements for X minutes. Then Plays “Please close the door” repeatedly through alexa.
Then… after the door is closed, announces “The door was left open for 3 minutes. Please contribute £2 towards the heating bill”
The last part doesn’t work. When the doors close the piston stops running. I’ve tried various combinations of “never cancel” etc
**4) Post a Green Snapshot of the
27/01/2023, 21:55:24 +529ms
+3ms ╔Received event [Front Outer Door Contact Sensor].switch = off with a delay of 25ms, canQueue: true, calledMyself: false
+14ms ║RunTime initialize > 13 LockT > 1ms > r9T > 3ms > pistonT > 1ms (first state access 6 m:9 4 9)
+17ms ║Runtime (8874 bytes) initialized in 3ms (v0.3.114.20230113_HE)
+19ms ║╔Execution stage started
+27ms ║║Comparison (enum) on stays (string) on = true (1ms)
+29ms ║║Comparison (enum) off stays (string) on = false (2ms)
+32ms ║║Cancelling any timed trigger schedule stays result false cancel any timers for condition 3
+35ms ║║Condition #3 evaluated false (13ms)
+41ms ║║Comparison (enum) off stays (string) on = false (1ms)
+43ms ║║Cancelling any timed trigger schedule stays result false cancel any timers for condition 4
+46ms ║║Condition #4 evaluated false (9ms)
+48ms ║║Condition group #2 evaluated false (condition changed) (25ms)
+50ms ║║Cancelling condition #1’s schedules…11 (st:13)
+51ms ║║Condition group #1 evaluated false (condition changed) (28ms)
+57ms ║╚Execution stage complete. (38ms)
+84ms ╚Event processed successfully (81ms)
27/01/2023, 21:55:22 +560ms
+4ms ╔Received event [Seafield Drive].time = 1674856522536 with a delay of 24ms, canQueue: true, calledMyself: false
+14ms ║RunTime initialize > 14 LockT > 1ms > r9T > 2ms > pistonT > 1ms (first state access 6 m:11 5 9)
+17ms ║Runtime (8860 bytes) initialized in 2ms (v0.3.114.20230113_HE)
+23ms ║╔Execution stage started
+40ms ║║Comparison (enum) on is (string) on = true (1ms)
+41ms ║║Comparison (enum) on is (string) on = true (1ms)
+42ms ║║Condition #9 evaluated true (11ms)
+43ms ║║Condition group #8 evaluated true (condition did not change) (12ms)
+44ms ║║Condition group #7 evaluated true (condition did not change) (13ms)
+218ms ║║Executed device command [Echo - Office Echo Show].setVolumeSpeakAndRestore(100.0,Please Close the Door,30.0) (167ms)
+224ms ║║Executed virtual command [Echo - Office Echo Show].wait [5000] (1ms)
+227ms ║║Requesting wake up at Fri, Jan 27 2023 @ 9:55:27 PM GMT (in 4999ms) for 11 (st:13)
+232ms ║╚Execution stage complete. (208ms)
+286ms ║Setting up scheduled job for Fri, Jan 27 2023 @ 9:55:27 PM GMT (in 4987ms)
+288ms ╚Event processed successfully (284ms)
27/01/2023, 21:55:17 +267ms
+3ms ╔Received event [Seafield Drive].time = 1674856517242 with a delay of 25ms, canQueue: true, calledMyself: false
+13ms ║RunTime initialize > 12 LockT > 0ms > r9T > 3ms > pistonT > 1ms (first state access 4 m:9 4 8)
+16ms ║Runtime (8853 bytes) initialized in 3ms (v0.3.114.20230113_HE)
+28ms ║║Condition #3 evaluated true (1ms)
+36ms ║║Comparison (enum) off stays (string) on = false (1ms)
+39ms ║║Cancelling any timed trigger schedule stays result false cancel any timers for condition 4
+41ms ║║Condition #4 evaluated false (12ms)
+43ms ║║Condition group #2 evaluated true (condition changed) (16ms)
+45ms ║║Condition group #1 evaluated true (condition changed) (19ms)
+53ms ║║Calculating (integer)0 - (integer)1 >> (integer)-1
+58ms ║║Executed virtual command setVariable (2ms)
+67ms ║║Comparison (enum) on is (string) on = true (1ms)
+68ms ║║Comparison (enum) on is (string) on = true (1ms)
+70ms ║║Condition #9 evaluated true (10ms)
+72ms ║║Condition group #8 evaluated true (condition changed) (11ms)
+74ms ║║Condition group #7 evaluated true (condition changed) (14ms)
+263ms ║║Executed device command [Echo - Office Echo Show].setVolumeSpeakAndRestore(100.0,Please Close the Door,30.0) (181ms)
+269ms ║║Executed virtual command [Echo - Office Echo Show].wait [5000] (1ms)
+271ms ║║Requesting wake up at Fri, Jan 27 2023 @ 9:55:22 PM GMT (in 4998ms) for 11 (st:13)
+275ms ║╚Execution stage complete. (253ms)
+327ms ║Setting up scheduled job for Fri, Jan 27 2023 @ 9:55:22 PM GMT (in 4988ms)
+329ms ╚Event processed successfully (326ms)
27/01/2023, 21:55:12 +135ms
+4ms ╔Received event [Front Outer Door Contact Sensor].switch = on with a delay of 55ms, canQueue: true, calledMyself: false
+86ms ║RunTime initialize > 85 LockT > 1ms > r9T > 75ms > pistonT > 73ms (first state access 4 m:9 5 80)
+89ms ║Runtime (8661 bytes) initialized in 75ms (v0.3.114.20230113_HE)
+99ms ║║Comparison (enum) on stays (string) on = true (1ms)
+101ms ║║Comparison (enum) on stays (string) on = true (1ms)
+110ms ║║Adding a timed trigger schedule stays result true scheduling timer for condition 3 wake up at Fri, Jan 27 2023 @ 9:55:17 PM GMT (in 4998ms) for 3 (st:3)
+112ms ║║Condition #3 evaluated false (16ms)
+120ms ║║Comparison (enum) off stays (string) on = false (2ms)
+124ms ║║Cancelling any timed trigger schedule stays result false cancel any timers for condition 4
+127ms ║║Condition #4 evaluated false (13ms)
+129ms ║║Condition group #2 evaluated false (condition did not change) (33ms)
+130ms ║║Condition group #1 evaluated false (condition did not change) (35ms)
+135ms ║╚Execution stage complete. (44ms)
+196ms ║Setting up scheduled job for Fri, Jan 27 2023 @ 9:55:17 PM GMT (in 4949ms)
+199ms ╚Event processed successfully (195ms)
