Im using smartthings to control my Grow Tent with a 4in1 sensor from Inovelli. I have piston for Temp Control: Temp over 27C turns on exhaust fan, when Temp gets equal to or below 25C exhaust fan turns off.
I have another Piston that controls the exhaust fan by time, to bring in fresh air: Every 90 minutes turn exhaust fan on for 15 minutes.
The problem is that the Timer piston will start, then turn off after a few minutes because the Temp control piston notices the temp is equal to or below 25C.
Id like the exhaust fan to continue running till the timer ends regardless of the temperature, when the Fresh Air timer is activated
Exhaust air timer piston will not run fan for full time as Temperature control piston will turn fan off due to current temperature.
Temperature Exhaust Fan
Fresh Air Timer
This log shows the Temperature Exhaust piston turning off the fan when it was turned on by the Fresh Air piston
5/23/2020, 12:18:17 AM +317ms
+2ms ╔Received event [Grow Tent Temp/Humidity/Motion Sensor].temperature = 25 with a delay of 187ms
+1037ms ║RunTime Analysis CS > 934ms > PS > 74ms > PE > 29ms > CE
+1040ms ║Runtime (37145 bytes) successfully initialized in 74ms (v0.3.110.20191009) (1038ms)
+1041ms ║╔Execution stage started
+1048ms ║║Comparison (decimal) 25.0 is_greater_than_or_equal_to (integer) 27 = false (1ms)
+1050ms ║║Condition #2 evaluated false (5ms)
+1051ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+1055ms ║║Comparison (decimal) 25.0 is_less_than_or_equal_to (integer) 25 = true (1ms)
+1057ms ║║Cancelling condition #6’s schedules…
+1057ms ║║Condition #6 evaluated true (5ms)
+1058ms ║║Cancelling condition #5’s schedules…
+1059ms ║║Condition group #5 evaluated true (state changed) (8ms)
+1061ms ║║Cancelling statement #7’s schedules…
+1089ms ║║Executed physical command [Tent intake / exhaust fans].off() (23ms)
+1097ms ║║Executed [Tent intake / exhaust fans].off (31ms)
+1101ms ║╚Execution stage complete. (60ms)
+1102ms ╚Event processed successfully (1102ms)
Any help with re-designing these pistons so that they both run correctly will be greatly appreciated.
Thanks in advance!
