In anticipation of @wcmore’s latest creation, I needed a Temperature API for my area. I found a PDF report with all the data and was able to copy it into a tab on my SmartThings Google Sheet. Using the read script, I created a block of code that can be used to extract the data for today’s date (or any given date).
Here is a sample of the data I collected:
The full year looks like this. I also have 3 and 7 day averages but I will wait to see the usage to determine which i want to use.
Here is the block of code that extracts the data. I just calculate what day of the year I need and then extract that row.
If you can find and create a spreadsheet with the data, this is a quick and easy way to access if you install (or already have) the google sheets read script.
