I would like to create a piston triggered by outside temperature (Checked every 30 min) That turns on two devices, so long as the temperature is below -32C these will cycle on 10 minutes and off for 20 minutes until the outside temperature rises at or above -32C then those two devices will turn off.
I am not familiar with using the GUI to do any of this sort of programming or some of the expressions used here, C++ and VBA were my jam some 15 years ago, and not so relevant today, so consider me a novice.
The intent is
if $twcweather.conditions.temperature is less than -32_C
Tank heater1 and Tank heater2
do
Turn on;
else $twcweather.conditions.temperature is = or greater than -32_C
Tank heater2 and Tank heater2
do
Turn off;
I can not figure out how to only turn the tanks on for 10 minutes and then off for 20 until the temperature is => -32_C
