I use Google Home Assistant to announce when a door opens. I use this as a sub-piston so that multiple pistons that get triggered can call it. When they do, they pass the door_name as a parameter. The sub-piston has some logic to only announce once every few hours (to not drive my wife crazy). In away mode, it also sends an SMS and an email.
The sub-piston should run and be done.
sub-piston likes to schedule itself to run. I can’t seem to figure out why. I even tried putting a logic in that ensures that if it runs directly (as in with door_name parameter empty), it will simply not run.
4) Post a Green Snapshot of the piston![image|45x37]![sub-piston|278x500] (upload://xK8WwMCzoDkDrcB1Jf27yjtZ9bq.png)
(UPLOAD YOUR IMAGE HERE)
Here is one. Why is it scheduling anything at 9PM? It clearly has something to do with my time constraint on when to broadcast.
11/29/2020, 11:06:40 AM +880ms
+0ms ╔Starting piston… (v0.3.110.20191009)
+303ms ║╔Subscribing to devices…
+344ms ║║Subscribing to Home.mode…
+408ms ║╚Finished subscribing (118ms)
+597ms ║Setting up scheduled job for Sun, Nov 29 2020 @ 9:00:00 PM EST (in 35598.523s), with 1 more job pending
+609ms ╚Piston successfully started (609ms)
Here is one more.
11/29/2020, 11:00:04 AM +312ms
+0ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 0ms
+153ms ║Runtime (60167 bytes) successfully initialized in 19ms (v0.3.110.20191009) (152ms)
+154ms ║╔Execution stage started
+202ms ║║the HTTP POST response with the brodacst message —Front Door is open— was {“response”:"",“audio”:"/server/audio?v=1606665600632",“success”:true}
+203ms ║║Executed virtual command log (1ms)
+206ms ║╚Execution stage complete. (52ms)
+208ms ║Setting up scheduled job for Sun, Nov 29 2020 @ 9:00:00 PM EST (in 35995.481s)
+217ms ╚Event processed successfully (217ms)
11/29/2020, 10:59:59 AM +59ms
+1ms ╔Received event [Home].time = 1606665600000 with a delay of -941ms
+159ms ║Runtime (60168 bytes) successfully initialized in 44ms (v0.3.110.20191009) (157ms)
+160ms ║╔Execution stage started
+191ms ║║This is started from another piston. Continue
+193ms ║║Executed virtual command log (2ms)
+206ms ║║Starting the Piston
+208ms ║║Executed virtual command log (2ms)
+211ms ║║Executed virtual command cancelTasks (1ms)
+224ms ║║Front Door
+226ms ║║Executed virtual command log (2ms)
+288ms ║║currentEventDate is Sun, Nov 29 2020 @ 11:00:00 AM EST
+288ms ║║previous_broadcast_time is Sun, Nov 29 2020 @ 9:00:00 AM EST
+289ms ║║Executed virtual command log (2ms)
+311ms ║║Executed virtual command setVariable (1ms)
+329ms ║║I see an event at LEAST 7200 seconds after the previous event
+331ms ║║Executed virtual command log (2ms)
+350ms ║║Executed virtual command setVariable (5ms)
+1184ms ║║Executed virtual command sendEmail (822ms)
+1285ms ║║This was triggered by Front Door. Enough time has passed or we are in AWAY mode. We WILL broadcast
+1286ms ║║Executed virtual command log (1ms)
+1300ms ║║updating previousChangeTime to Sun, Nov 29 2020 @ 11:00:00 AM EST
+1301ms ║║Executed virtual command log (2ms)
+1308ms ║║Executed virtual command setVariable (4ms)
+1312ms ║║Executed virtual command setVariable (1ms)
+1475ms ║║Executed virtual command httpRequest (150ms)
+1476ms ║║Requesting a wake up for Sun, Nov 29 2020 @ 11:00:20 AM EST (in 20.0s)
+1610ms ║╚Execution stage complete. (1450ms)
+1612ms ║Setting up scheduled job for Sun, Nov 29 2020 @ 11:00:20 AM EST (in 19.866s), with 1 more job pending
+1618ms ╚Event processed successfully (1617ms)
