Webcore is advising me that “This piston does not subscribe to any events”. I did have this working at one point, but did a partial re-write to accommodate some other scenarios, and I’ve buggered it in the process. Any help getting me back on track is greatly appreciated.
The intent of the piston is to utilize the AC temperature setpoint from the thermostat (captured to a variable in another piston) as a baseline and adapt the ceiling fan speed accordingly to keep the room near the target temperature. In the case of thermostat being turned off, it has a separate section to work with hard coded temperatures instead. There is also a separate section to accommodate one of us sleeping in late (mostly weekends) while the other has gotten up and woken up the house.
Some caveats: I do have separate automations that will turn on the ceiling fan if the humidifier in the room is running, or if the HVAC is running. These are intended to respectively spread the effect around the room. To accommodate these, I have restrictions that won’t turn the fan off unless they’re both dormant.
The piston is telling me it won’t trigger because it doesn’t subscribe to any events, and I can’t figure out where my logic is off.
There really aren’t any logs from ST for this at present, as it’s not making it to the triggering point.
I am however getting the following from webcore logs:
+398ms ║An error has occurred while subscribing: groovy.lang.MissingPropertyException: No such property: r for class: java.lang.Boolean
