I’ve made this piston be controlled with the operation state of “heating and idle” instead of setting actual thermostat heatpoint because I don’t want the heat to go above 22C ever.
I’m not sure but I feel like this whole piston could be better written and use thermostat heatpoint instead? the thermostat is a virtual thermostat with a device and the virtual switch is doing nothing and thats also another reason why I use the operation state to set the switch.
Question 1)
Can anyone help me improve this piston to use the thermostat setpoint (heatpoint) instead of operation state of heating / idle to set the virtual switch used?
Question 2)
Can anyone help me include a “defrost” event that only happens twice a night if no motion and current room temp is reached?
Question 3)
I have a event that if motion is detected and turbo is false, send a ifttt command to activate my turbo option for my heatpump.
I would also like to increase the temperature by 1 everytime current temp changes until the actual room temperature is reached.
I live in a cold climate and I really would like to reach comfortable temperature as quickly as possible!
Thank you kindly for any help offered, would mean alot! donation for couple of beers is possible
Best regards,
D
