I was hoping for some clarification on this piston I found searching around. Credit to @michicago for the piston.
When both my wife and I leave, the thermostat sets the cooling temperature to 76 degrees or the heating temperature to 65 degrees. When we return home, it goes back to however we had it set before we left.
At the bottom it says “resumeProgram”. Is there something else I need for this to work? Or does that just tell the thermostat to go back to it’s original set point?
N/A
