I have a bunch of normally well-behaved tile pistons. This morning I noticed one of my outdoor lights (driveway light) was on.
A tile that reports status (unless I click it).
As I said, I noticed an outdoor light on. The piston reports status in tile form on several lights, and shouldn’t turn any on unless I’m the turner-oner!
When I go to the ide and check “List Events” for that switch, it says: Outside Light Status Tile sent on command to driveway light. [2020-01-10 6:44:14.487 AM EST]
The problem light is Switch 4 (Driveway)
[image|45x37]
This is a day back, I can go further if needed.
1/10/2020, 7:24:31 AM +546ms
+1111ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 6:53:26 AM +653ms
+949ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 6:53:24 AM +527ms
+896ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 6:53:19 AM +257ms
+901ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 6:44:40 AM +546ms
+1167ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 6:44:18 AM +877ms
+1177ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 6:43:55 AM +984ms
+9431ms ║Piston waited at a semaphore for 9264ms
+10231ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 6:43:55 AM +133ms
+995ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 6:43:55 AM +129ms
+977ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/10/2020, 12:05:59 AM +754ms
+876ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 11:16:21 PM +574ms
+9918ms ║Piston waited at a semaphore for 9767ms
+11059ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 11:16:21 PM +522ms
+10148ms ║Piston waited at a semaphore for 10024ms
+10961ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 11:16:21 PM +300ms
+1236ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 11:12:58 PM +568ms
+8914ms ║Piston waited at a semaphore for 8766ms
+9944ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 11:12:58 PM +267ms
+9169ms ║Piston waited at a semaphore for 9013ms
+10094ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 11:12:58 PM +676ms
+1153ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 11:12:57 PM +285ms
+1269ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 10:28:07 PM +511ms
+1034ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 10:27:55 PM +203ms
+9914ms ║Piston waited at a semaphore for 9765ms
+11037ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 10:27:55 PM +51ms
+9896ms ║Piston waited at a semaphore for 9765ms
+10687ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 10:27:54 PM +723ms
+1187ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 10:25:15 PM +370ms
+1194ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 10:25:14 PM +28ms
+1186ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 10:25:12 PM +39ms
+1182ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 7:54:40 PM +623ms
+1089ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 7:54:19 PM +268ms
+10237ms ║Piston waited at a semaphore for 10015ms
+11238ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 7:54:20 PM +276ms
+1334ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 7:54:19 PM +158ms
+998ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 7:53:10 PM +313ms
+1241ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 7:48:13 PM +228ms
+932ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 7:47:16 PM +38ms
+1035ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 7:45:05 PM +843ms
1/9/2020, 6:20:37 PM +478ms
+988ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 6:16:43 PM +652ms
+1232ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 6:12:40 PM +787ms
+10216ms ║Piston waited at a semaphore for 10071ms
+11260ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 6:12:40 PM +751ms
+939ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 6:12:28 PM +32ms
+1338ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:44:28 PM +196ms
+9660ms ║Piston waited at a semaphore for 9518ms
+10777ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:44:27 PM +686ms
+10157ms ║Piston waited at a semaphore for 10018ms
+11132ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:44:27 PM +532ms
+1198ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:43:26 PM +325ms
1/9/2020, 5:43:10 PM +99ms
+9771ms ║Piston waited at a semaphore for 9587ms
+10907ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:43:09 PM +739ms
+9961ms ║Piston waited at a semaphore for 9768ms
+11117ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:43:09 PM +456ms
+946ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:37:37 PM +46ms
+10473ms ║Piston waited at a semaphore for 10104ms
+11534ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:37:36 PM +920ms
1/9/2020, 5:35:48 PM +262ms
+1043ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:27:10 PM +802ms
+10159ms ║Piston waited at a semaphore for 10014ms
+11168ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:27:10 PM +607ms
+10253ms ║Piston waited at a semaphore for 10015ms
+11233ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:27:10 PM +567ms
+1074ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:22:11 PM +691ms
+1266ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:19:39 PM +802ms
+1238ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:19:07 PM +965ms
+10228ms ║Piston waited at a semaphore for 10072ms
+11287ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:19:07 PM +957ms
+10224ms ║Piston waited at a semaphore for 10100ms
+11052ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:19:07 PM +861ms
+10129ms ║Piston waited at a semaphore for 10015ms
+10942ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:19:07 PM +801ms
+1164ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:10:56 PM +380ms
+1159ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:10:34 PM +91ms
+1264ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:09:55 PM +187ms
+11358ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:09:55 PM +176ms
+1245ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:07:15 PM +264ms
+10171ms ║Piston waited at a semaphore for 10017ms
+11285ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:07:15 PM +242ms
+1084ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:07:09 PM +713ms
+1348ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:07:05 PM +138ms
+1143ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:06:55 PM +143ms
+10134ms ║Piston waited at a semaphore for 10019ms
+10951ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 5:06:55 PM +98ms
+867ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 4:37:49 PM +802ms
+1225ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 4:27:48 PM +460ms
+9788ms ║Piston waited at a semaphore for 9595ms
+10909ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/9/2020, 4:27:47 PM +844ms
+967ms ║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
