I used the example code (2gw6k) and it seems to be executing correctly yet the tiles are not displayed. I’m sure I missed something.
Thanks in advance
Cheers,
Ray
Cheers,
Ray
In the piston you have categories.
In settings you can set your categories and you can set the attributes for them.
Here is my one.
Note to the right you can select what the category is for.
I use Tiles/details which means you get a Tile and also a line that describes the piston.
Not sure if you have done this but this is what you need to do.
Please Don’t forget to check the
solution box on @bobbles reply to let others know how to solve the same problem.
Hi,
I’m using presence example v78tz found here: https://wiki.webcore.co/Samples#Presence_Tiles but nothing’s showing no matter what attributes I set? I’ve only changed the parameters highlighted and followed the instructions exactly - anyone know what am I missing?
