Tiles at staging.webcore.co are not updating when I expect them to.
I’ve created a proof of concept for a “dashboard” using tiles to indicate doors that are open and closed. These are all doors that should remain closed, so if they are closed the icon is green (and shows a closed door) and when they are open the icon is red (and shows an open door). I can tell from the logs that it is executing as expected.
Even though the logs show everything is working in the piston, the tiles don’t change colors until I click on one of them to execute the code again. Since the logs are showing that webcore detects the change to the contact sensor and executes the code (correctly) immediately, I expected that the tiles would also update at the same time.
(Note that I have logging set to minimal because I’ve included more helpful (IMO) logging statements directly in the coding.)
2/12/2022, 3:44:36 PM +478ms
+2ms ╔Received event [Test Contact Sensor].contact = open with a delay of 26ms, canQueue: true, calledMyself: false
+89ms ║Device is Basement door
+96ms ║contact is open set to false
+106ms ║index is currently 0
+127ms ║Device name is Basement Door
+135ms ║contact-is-open is false
+153ms ║Piston tile text is closed
+188ms ║index incremented to 1
+210ms ║Device is Freezer
+217ms ║contact is open set to false
+227ms ║index is currently 1
+247ms ║Device name is Freezer
+254ms ║contact-is-open is false
+272ms ║Piston tile text is closed
+306ms ║index incremented to 2
+328ms ║Device is Garage Door Tilt
+335ms ║contact is open set to false
+344ms ║index is currently 2
+365ms ║Device name is Garage Door
+372ms ║contact-is-open is false
+390ms ║Piston tile text is closed
+424ms ║index incremented to 3
+445ms ║Device is Sliding door
+453ms ║contact is open set to false
+462ms ║index is currently 3
+483ms ║Device name is Sliding Door
+490ms ║contact-is-open is false
+508ms ║Piston tile text is closed
+542ms ║index incremented to 4
+562ms ║Device is Test Contact Sensor
+569ms ║contact is open set to true
+579ms ║index is currently 4
+599ms ║Device name is Test Sensor
+607ms ║contact-is-open is true
+625ms ║Piston tile text is open
+659ms ║index incremented to 5
+673ms ╚Event processed successfully (671ms)
