Hi. I can use the age and agePrevious functions to determine how long since a door opened/closed.
i.e.
and
This needs no trigger, I can call whenever,
I’m assuming this will screw up if the events roll-over midnight, so is there a better way of using this kind of expression, again, avoiding the need to say, store a variable at the point of the contact changing?
Also, is it possible to actually grab a timestamp of sorts for this? I’d like to be able to display info on when the door last opened/closed.
Hope that makes sense. Ta!
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
