I have setup a piston that runs at various times during the day which either sets a heating TRV to on and a temperature or switches it to off/eco ie lower temperature. The program is split into two, ie at certain times it runs part of the code and at other the other part of the code. This is controlled by setting the varible “Off” to true or false at the trigger time…
I would expect the code to run the correct part of the code depending on the time it was triggered at.
Often it is running correctly. But sometimes eg today at 9am it turned the heating up rather than down. The piston status/logging shows it did indeed set the TRV up to 25c but I can’t see why it did that when the logic (I think) says turn the TRV down.
12/18/2020, 9:00:51 AM +125ms
+0ms ╔Received event [Home].time = 1608282051989 with a delay of -865ms
+288ms ║RunTime Analysis CS > 114ms > PS > 113ms > PE > 61ms > CE
+291ms ║Runtime (47544 bytes) successfully initialized in 113ms (v0.3.10e.20190628) (289ms)
+292ms ║╔Execution stage started
+512ms ║║Executed physical command [Bedroom 1 TRV].booston() (134ms)
+513ms ║║Executed [Bedroom 1 TRV].booston (136ms)
+525ms ║║Calculating (string) Fri, Dec 18 2020 @ 9:00:51 AM GMT + (string) Set Temperature to >> (string) Fri, Dec 18 2020 @ 9:00:51 AM GMT Set Temperature to
+528ms ║║Calculating (string) Fri, Dec 18 2020 @ 9:00:51 AM GMT Set Temperature to + (string) 25 >> (string) Fri, Dec 18 2020 @ 9:00:51 AM GMT Set Temperature to 25
+531ms ║║Calculating (string) Fri, Dec 18 2020 @ 9:00:51 AM GMT Set Temperature to 25 + (string) with Boost >> (string) Fri, Dec 18 2020 @ 9:00:51 AM GMT Set Temperature to 25 with Boost
+535ms ║║Executed virtual command [Bedroom 1 TRV].setState (1ms)
+542ms ║║Calculating (string) Bedroom 1 TRV: Set Temperature to + (string) 25 >> (string) Bedroom 1 TRV: Set Temperature to 25
+545ms ║║Calculating (string) Bedroom 1 TRV: Set Temperature to 25 + (string) With Boost >> (string) Bedroom 1 TRV: Set Temperature to 25 With Boost
+549ms ║║Bedroom 1 TRV: Set Temperature to 25 With Boost
+552ms ║║Executed virtual command [Bedroom 1 TRV].log (4ms)
+666ms ║╚Execution stage complete. (375ms)
+672ms ║Setting up scheduled job for Fri, Dec 18 2020 @ 12:00:00 PM GMT (in 10748.204s), with 6 more jobs pending
+680ms ╚Event processed successfully (681ms)
12/18/2020, 9:00:38 AM +155ms
+1ms ╔Received event [Home].time = 1608282039538 with a delay of -1383ms
+10270ms ║RunTime Analysis CS > 93ms > PS > 10107ms > PE > 70ms > CE
+10271ms ║Piston waited at a semaphore for 10082ms
+10274ms ║Runtime (47622 bytes) successfully initialized in 10107ms (v0.3.10e.20190628) (10272ms)
+10275ms ║╔Execution stage started
+10276ms ║╚Execution stage complete. (1ms)
+10279ms ║Setting up scheduled job for Fri, Dec 18 2020 @ 9:00:51 AM GMT (in 3.556s), with 7 more jobs pending
+10288ms ╚Event processed successfully (10288ms)
12/18/2020, 9:00:38 AM +114ms
+1ms ╔Received event [Home].time = 1608282039538 with a delay of -1424ms
+320ms ║RunTime Analysis CS > 118ms > PS > 129ms > PE > 73ms > CE
+323ms ║Runtime (47545 bytes) successfully initialized in 129ms (v0.3.10e.20190628) (321ms)
+324ms ║╔Execution stage started
+8869ms ║║Executed physical command [Bedroom 1 TRV].setHeatingSetpoint([25.0]) (8508ms)
+8870ms ║║Executed [Bedroom 1 TRV].setHeatingSetpoint (8510ms)
+8873ms ║║Executed virtual command [Bedroom 1 TRV].wait (0ms)
+8875ms ║║Requesting a wake up for Fri, Dec 18 2020 @ 9:00:51 AM GMT (in 5.0s)
+8880ms ║╚Execution stage complete. (8555ms)
+8883ms ║Setting up scheduled job for Fri, Dec 18 2020 @ 9:00:51 AM GMT (in 4.993s), with 7 more jobs pending
+8911ms ╚Event processed successfully (8911ms)
12/18/2020, 9:00:32 AM +313ms
+1ms ╔Received event [Home].execute = recovery with a delay of 50ms
+87ms ║RunTime Analysis CS > 15ms > PS > 13ms > PE > 59ms > CE
+90ms ║Runtime (47533 bytes) successfully initialized in 13ms (v0.3.10e.20190628) (88ms)
+101ms ║║Comparison (enum) on is (string) on = true (1ms)
+102ms ║║Condition #63 evaluated true (8ms)
+103ms ║║Condition group #null evaluated true (state did not change) (9ms)
+105ms ║║Cancelling statement #81's schedules...
+108ms ║║Executed virtual command wait (0ms)
+109ms ║║Waiting for 2000ms
+2114ms ║║Comparison (time) 32434425 happens_daily_at (time) 27000000 = false (0ms)
+2116ms ║║Cancelling condition #46's schedules...
+2116ms ║║Condition #46 evaluated false (4ms)
+2117ms ║║Cancelling statement #46's schedules...
+2120ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 7:30:00 AM GMT
+2125ms ║║Comparison (time) 32434436 happens_daily_at (time) 79200000 = false (0ms)
+2126ms ║║Condition #76 evaluated false (4ms)
+2127ms ║║Cancelling statement #76's schedules...
+2130ms ║║Requesting time schedule wake up at Fri, Dec 18 2020 @ 10:00:00 PM GMT
+2132ms ║║Cancelling condition #45's schedules...
+2133ms ║║Condition group #45 evaluated false (state changed) (21ms)
+2137ms ║║Comparison (time) 32434449 happens_daily_at (time) 32400000 = false (0ms)
+2139ms ║║Condition #50 evaluated false (3ms)
+2140ms ║║Cancelling statement #50's schedules...
+2143ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 9:00:00 AM GMT
+2147ms ║║Comparison (time) 32434458 happens_daily_at (time) 43200000 = false (0ms)
+2148ms ║║Condition #77 evaluated false (3ms)
+2149ms ║║Cancelling statement #77's schedules...
+2152ms ║║Requesting time schedule wake up at Fri, Dec 18 2020 @ 12:00:00 PM GMT
+2156ms ║║Comparison (time) 32434467 happens_daily_at (time) 57600000 = false (1ms)
+2157ms ║║Condition #78 evaluated false (3ms)
+2158ms ║║Cancelling statement #78's schedules...
+2161ms ║║Requesting time schedule wake up at Fri, Dec 18 2020 @ 4:00:00 PM GMT
+2165ms ║║Comparison (time) 32434476 happens_daily_at (time) 60000 = false (0ms)
+2166ms ║║Condition #79 evaluated false (3ms)
+2168ms ║║Cancelling statement #79's schedules...
+2171ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 12:01:00 AM GMT
+2175ms ║║Comparison (time) 32434486 happens_daily_at (time) 5400000 = false (0ms)
+2176ms ║║Condition #80 evaluated false (3ms)
+2177ms ║║Cancelling statement #80's schedules...
+2180ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 1:30:00 AM GMT
+2182ms ║║Condition group #49 evaluated false (state did not change) (47ms)
+2189ms ║║Comparison (boolean) false is (boolean) true = false (2ms)
+2190ms ║║Condition #56 evaluated false (5ms)
+2191ms ║║Condition group #55 evaluated false (state did not change) (7ms)
+2205ms ║║Calculating (integer) 25 - (integer) 4 >> (integer) 21
+2208ms ║║Comparison (decimal) 20.87 is_less_than_or_equal_to (integer) 21 = true (2ms)
+2209ms ║║Condition #26 evaluated true (16ms)
+2210ms ║║Condition group #25 evaluated true (state did not change) (17ms)
+2212ms ║║Cancelling statement #29's schedules...
+2219ms ║║Skipped execution of physical command [Bedroom 1 TRV].auto([]) because it would make no change to the device. (4ms)
+2220ms ║║Executed [Bedroom 1 TRV].auto (6ms)
+2223ms ║║Executed virtual command [Bedroom 1 TRV].wait (0ms)
+2224ms ║║Requesting a wake up for Fri, Dec 18 2020 @ 9:00:39 AM GMT (in 5.0s)
+2234ms ║╚Execution stage complete. (2143ms)
+2237ms ║Setting up scheduled job for Fri, Dec 18 2020 @ 9:00:39 AM GMT (in 4.988s), with 7 more jobs pending
+2246ms ╚Event processed successfully (2246ms)
12/18/2020, 9:00:26 AM +111ms
+0ms ╔Received event [Home].time/recovery = 1608282026105 with a delay of 5ms
+252ms ║RunTime Analysis CS > 96ms > PS > 97ms > PE > 60ms > CE
+256ms ║Runtime (47544 bytes) successfully initialized in 97ms (v0.3.10e.20190628) (255ms)
+257ms ║╔Execution stage started
+270ms ║║Comparison (enum) on is (string) on = true (1ms)
+272ms ║║Condition #63 evaluated true (10ms)
+273ms ║║Condition group #null evaluated true (state did not change) (11ms)
+275ms ║║Cancelling statement #81's schedules...
+278ms ║║Executed virtual command wait (1ms)
+279ms ║║Waiting for 2000ms
+2285ms ║║Comparison (time) 32428394 happens_daily_at (time) 27000000 = false (1ms)
+2286ms ║║Cancelling condition #46's schedules...
+2287ms ║║Condition #46 evaluated false (5ms)
+2288ms ║║Cancelling statement #46's schedules...
+2292ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 7:30:00 AM GMT
+2296ms ║║Comparison (time) 32428405 happens_daily_at (time) 79200000 = false (0ms)
+2298ms ║║Condition #76 evaluated false (4ms)
+2299ms ║║Cancelling statement #76's schedules...
+2302ms ║║Requesting time schedule wake up at Fri, Dec 18 2020 @ 10:00:00 PM GMT
+2304ms ║║Cancelling condition #45's schedules...
+2305ms ║║Condition group #45 evaluated false (state changed) (23ms)
+2310ms ║║Comparison (time) 32428419 happens_daily_at (time) 32400000 = true (0ms)
+2311ms ║║Time restriction check passed
+2313ms ║║Cancelling condition #50's schedules...
+2314ms ║║Condition #50 evaluated true (5ms)
+2315ms ║║Cancelling statement #50's schedules...
+2319ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 9:00:00 AM GMT
+2322ms ║║Cancelling condition #49's schedules...
+2323ms ║║Condition group #49 evaluated true (state changed) (14ms)
+2325ms ║║Cancelling statement #39's schedules...
+2328ms ║║Executed virtual command setVariable (1ms)
+2335ms ║║Comparison (boolean) true is (boolean) true = true (2ms)
+2336ms ║║Cancelling condition #56's schedules...
+2337ms ║║Condition #56 evaluated true (6ms)
+2339ms ║║Cancelling condition #55's schedules...
+2340ms ║║Condition group #55 evaluated true (state changed) (9ms)
+2343ms ║║Cancelling statement #57's schedules...
+6005ms ║║Executed physical command [Bedroom 1 TRV].configure() (3657ms)
+6006ms ║║Executed [Bedroom 1 TRV].configure (3659ms)
+6009ms ║║Executed virtual command [Bedroom 1 TRV].wait (1ms)
+6010ms ║║Requesting a wake up for Fri, Dec 18 2020 @ 9:00:42 AM GMT (in 10.0s)
+6072ms ║╚Execution stage complete. (5815ms)
+6076ms ║Setting up scheduled job for Fri, Dec 18 2020 @ 9:00:42 AM GMT (in 9.936s), with 7 more jobs pending
+6083ms ╚Event processed successfully (6083ms)
12/18/2020, 7:30:21 AM +65ms
+1ms ╔Received event [Home].time = 1608276622889 with a delay of -1824ms
+113ms ║RunTime Analysis CS > 20ms > PS > 22ms > PE > 71ms > CE
+116ms ║Runtime (47517 bytes) successfully initialized in 22ms (v0.3.10e.20190628) (114ms)
+117ms ║╔Execution stage started
+2241ms ║║Executed physical command [Bedroom 1 TRV].booston() (2088ms)
+2242ms ║║Executed [Bedroom 1 TRV].booston (2091ms)
+2250ms ║║Calculating (string) Fri, Dec 18 2020 @ 7:30:23 AM GMT + (string) Set Temperature to >> (string) Fri, Dec 18 2020 @ 7:30:23 AM GMT Set Temperature to
+2253ms ║║Calculating (string) Fri, Dec 18 2020 @ 7:30:23 AM GMT Set Temperature to + (string) 25 >> (string) Fri, Dec 18 2020 @ 7:30:23 AM GMT Set Temperature to 25
+2256ms ║║Calculating (string) Fri, Dec 18 2020 @ 7:30:23 AM GMT Set Temperature to 25 + (string) with Boost >> (string) Fri, Dec 18 2020 @ 7:30:23 AM GMT Set Temperature to 25 with Boost
+2259ms ║║Executed virtual command [Bedroom 1 TRV].setState (1ms)
+2266ms ║║Calculating (string) Bedroom 1 TRV: Set Temperature to + (string) 25 >> (string) Bedroom 1 TRV: Set Temperature to 25
+2269ms ║║Calculating (string) Bedroom 1 TRV: Set Temperature to 25 + (string) With Boost >> (string) Bedroom 1 TRV: Set Temperature to 25 With Boost
+2273ms ║║Bedroom 1 TRV: Set Temperature to 25 With Boost
+2275ms ║║Executed virtual command [Bedroom 1 TRV].log (3ms)
+2289ms ║╚Execution stage complete. (2172ms)
+2294ms ║Setting up scheduled job for Fri, Dec 18 2020 @ 9:00:00 AM GMT (in 5376.642s), with 6 more jobs pending
+2301ms ╚Event processed successfully (2301ms)
12/18/2020, 7:30:11 AM +119ms
+0ms ╔Received event [Home].time = 1608276612686 with a delay of -1568ms
+157ms ║RunTime Analysis CS > 46ms > PS > 51ms > PE > 61ms > CE
+160ms ║Runtime (47517 bytes) successfully initialized in 51ms (v0.3.10e.20190628) (159ms)
+161ms ║╔Execution stage started
+6764ms ║║Executed physical command [Bedroom 1 TRV].setHeatingSetpoint([25.0]) (6568ms)
+6765ms ║║Executed [Bedroom 1 TRV].setHeatingSetpoint (6570ms)
+6768ms ║║Executed virtual command [Bedroom 1 TRV].wait (1ms)
+6769ms ║║Requesting a wake up for Fri, Dec 18 2020 @ 7:30:22 AM GMT (in 5.0s)
+6774ms ║╚Execution stage complete. (6613ms)
+6778ms ║Setting up scheduled job for Fri, Dec 18 2020 @ 7:30:22 AM GMT (in 4.993s), with 7 more jobs pending
+6784ms ╚Event processed successfully (6784ms)
12/18/2020, 7:29:59 AM +80ms
+1ms ╔Received event [Home].time = 1608276600000 with a delay of -921ms
+161ms ║RunTime Analysis CS > 18ms > PS > 24ms > PE > 119ms > CE
+163ms ║Runtime (47508 bytes) successfully initialized in 24ms (v0.3.10e.20190628) (161ms)
+164ms ║╔Execution stage started
+178ms ║║Comparison (enum) on is (string) on = true (2ms)
+179ms ║║Condition #63 evaluated true (9ms)
+180ms ║║Condition group #null evaluated true (state did not change) (10ms)
+183ms ║║Cancelling statement #81's schedules...
+186ms ║║Executed virtual command wait (0ms)
+187ms ║║Waiting for 2000ms
+2192ms ║║Comparison (time) 27001270 happens_daily_at (time) 27000000 = true (1ms)
+2193ms ║║Time restriction check passed
+2196ms ║║Cancelling condition #46's schedules...
+2197ms ║║Condition #46 evaluated true (6ms)
+2197ms ║║Cancelling statement #46's schedules...
+2200ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 7:30:00 AM GMT
+2203ms ║║Cancelling condition #45's schedules...
+2204ms ║║Condition group #45 evaluated true (state changed) (15ms)
+2206ms ║║Cancelling statement #35's schedules...
+2218ms ║║Executed virtual command setVariable (2ms)
+2223ms ║║Comparison (time) 27001301 happens_daily_at (time) 32400000 = false (0ms)
+2224ms ║║Condition #50 evaluated false (4ms)
+2225ms ║║Cancelling statement #50's schedules...
+2228ms ║║Requesting time schedule wake up at Fri, Dec 18 2020 @ 9:00:00 AM GMT
+2232ms ║║Comparison (time) 27001310 happens_daily_at (time) 43200000 = false (0ms)
+2234ms ║║Condition #77 evaluated false (3ms)
+2235ms ║║Cancelling statement #77's schedules...
+2237ms ║║Requesting time schedule wake up at Fri, Dec 18 2020 @ 12:00:00 PM GMT
+2242ms ║║Comparison (time) 27001320 happens_daily_at (time) 57600000 = false (0ms)
+2243ms ║║Condition #78 evaluated false (4ms)
+2244ms ║║Cancelling statement #78's schedules...
+2247ms ║║Requesting time schedule wake up at Fri, Dec 18 2020 @ 4:00:00 PM GMT
+2252ms ║║Comparison (time) 27001330 happens_daily_at (time) 60000 = false (1ms)
+2253ms ║║Condition #79 evaluated false (3ms)
+2255ms ║║Cancelling statement #79's schedules...
+2257ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 12:01:00 AM GMT
+2262ms ║║Comparison (time) 27001340 happens_daily_at (time) 5400000 = false (0ms)
+2263ms ║║Cancelling condition #80's schedules...
+2264ms ║║Condition #80 evaluated false (4ms)
+2265ms ║║Cancelling statement #80's schedules...
+2268ms ║║Requesting time schedule wake up at Sat, Dec 19 2020 @ 1:30:00 AM GMT
+2270ms ║║Cancelling condition #49's schedules...
+2271ms ║║Condition group #49 evaluated false (state changed) (51ms)
+2278ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+2279ms ║║Cancelling condition #56's schedules...
+2280ms ║║Condition #56 evaluated false (6ms)
+2281ms ║║Cancelling condition #55's schedules...
+2282ms ║║Condition group #55 evaluated false (state changed) (9ms)
+2298ms ║║Calculating (integer) 25 - (integer) 4 >> (integer) 21
+2301ms ║║Comparison (decimal) 15.59 is_less_than_or_equal_to (integer) 21 = true (1ms)
+2302ms ║║Condition #26 evaluated true (18ms)
+2303ms ║║Condition group #25 evaluated true (state did not change) (19ms)
+2306ms ║║Cancelling statement #29's schedules...
+8599ms ║║Executed physical command [Bedroom 1 TRV].auto() (6291ms)
+8600ms ║║Executed [Bedroom 1 TRV].auto (6293ms)
+8604ms ║║Executed virtual command [Bedroom 1 TRV].wait (0ms)
+8605ms ║║Requesting a wake up for Fri, Dec 18 2020 @ 7:30:12 AM GMT (in 5.0s)
+8862ms ║╚Execution stage complete. (8697ms)
+8866ms ║Setting up scheduled job for Fri, Dec 18 2020 @ 7:30:12 AM GMT (in 4.741s), with 7 more jobs pending
+8873ms ╚Event processed successfully (8873ms)
