I am new to WebCore and trying to find a way with my DOME Water Shutoff Valve to have a timer on it. This valve is made to shut OFF the valve to the water main in case of a leak or some event. I am planning to use it a bit opposite.
The DOME valve is always OFF when physically attached to water fill connection to my pool. I want to manually turn the valve ON to fill the pool but have a timer run to automatically shut OFF after {25} minutes.
The only thing similar I have found is how to use a motion sensor to turn a light ON and then OFF again after X minutes.
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
