TP-Link Smart Plug Mini
Unable to access “Device” commands for plugs in WebCoRE. Only “Location” commands appear.
When installing WebCoRE, the plugs were not automatically added, I had to manually add them using “Select devices by capability” under the “Switches” category.
Under SmartThings Groovy IDE, if i look at devices for my location, all the TP-Link plugs show as “placeholder” under “type”
Not sure if there is a device handler I’m missing, but I appreciate any help.
Haven’t gotten this far yet…
Sorry if this is the wrong place to post this question, I’m just starting to learn WebCoRE and am still in the early learning stage.
Thanks.
You might want to check in the ST forum and ask which device handler you should pick under the Type field.
