Trigger if a Certain Routine runs
Is there a way for me to create a condition so that if a certain Routine in ST runs then carry out action?
The only thing I can find is in the screenshot below. But it wan’ts me to compare to a routine. But instead I want if a certain routine runs
This is what you want.
It’s basically saying IF routine All Lights Off executes THEN DO…
Oh ok, you wouldn’t think it because it seems like when any routine executes compare to which also doesn’t make sense.
Yea the wording doesn’t quite seem right but when you select it and see it in the script it will make sense.
I have several pistons that trigger on the execution of a routine and this is the only way to do it.
