I have a piston that text’s me under certain circumstances. It triggers primarily by a change in temperature from a sensor. I would like to get a notification no more often than every 15 minutes. However the temperature can sometimes change every few minutes, and if I ignore it for a bit (don’t open the windows) it can get annoying.
I’ve thought of changing to a timer (run every 15 minutes, then an if statement inside of that) but I believe there is a more elegant solution.
