I’ve created a piston that records the date/time an action occurs. I need the piston to alert me if that same action does not occur again within 12 hours. Around 5 separate actions need to be tracked, each occurring independently.
Record the date/time of various actions. Currently I’m using date/time variables. When the action occurs, one variable is assigned $now, and the 2nd is set using the expression {addHours($now, 12)}. If the action is not repeated before the current time surpasses the 2nd variable, send me an alert
Simplified Example: I push a button at 9am. If that same button is not pushed again before 9pm, trigger an alert. If the button is pushed before 9pm (for example at 7pm), the piston resets to watch if it is pushed before 7:00am.
I can’t figure out the best way to trigger the alert. I’ve attempted using a boolean variable set to True when the action occurs. Then I included “wait 12 hours” and set variable to “False”. If variable remains “False” for 5 seconds, trigger an alert. However, this doesn’t seem very efficient, especially if multiple actions are being tracked.
Being of a sensitive nature, I’d rather not post a screenshot.
N/A
