I’m setting up a group of lights for a room. I am using a virtual dimmer switch to control all lights in a room.
Problem is, if I turn on any lights individually, the Virtual Switch doesn’t change state. So if I have one light on, and then try to turn the room off nothing happens because WebCore doesn’t see any change in the Virtual Switch.
When I say “turn room on” or “turn room off” I want all lights in that room to turn on or off regardless of current virtual switch state.
See above.
I’m not sure what the best solution is to this, but I was thinking if there is a way to determine if a device is the target of a command even if it doesn’t trigger a change.
so something like:
if
- VirtualRoom is TargetOfCommand
then
- with (all lights in room)
- set switches to VirtualRoom’s switch
Any help would be great!
