I’d like to trigger a piston with Alexa. I’m currently using a virtual switch and that works using the classic app to turn it on/off. However, when I ask Alexa to turn on the switch to execute the piston, it says it’s not supported. Thoughts?
Trigger Piston with Alexa but not with a Virtual Switch
I don’t know if alexa can go ahead and read your ST APP switches without DISCOVERY.
For alexa routines, you need to create a routine in alexa app.
Go to alexa app and choose discover devices.
Go to routines.
Alexa “Turn on the lights”
Alexa turns ON switch X
Right. The dimming piston you helped with uses a virtual switch to execute and Alexa will turn it on/off. I think the difference is that piston actually uses smart switches to turn on/off the lights within the piston. The one above does not. It’s a standard single pole switch that controls two RGB can lights.
*** Apparently I have to wait an hour to post. Hopefully I can edit this post to say that the switch is in Alexa’s Device list. ***
Yes I saw your edit.
Try creating an Alexa routine to turn on and off that switch…
ps : I’m assuming you are using an echo device not alexa integreted speaker because they CAN have that problem.
