I’m trying to create a piston that will turn on and off my freezer based on temperature. This is a deep freezer and in Celsius runs from -18C to -22C, in F it runs 0 to -4f. In Smartthings I see the temperature listed and shown as -22C. In Webcore I cannot utilize the “-” (negative) value and thus would be limited to values 0 and above.
Ability to enter in a negative value
In Global variables the negative becomes an underscore. In the rules there is no option to enter a negative value
**4) Post a Green Snapshot of the piston![image|45x37] Version:1.0
only when
Temp_Freezer (temperature1)'s temperature is greater than 0°F
execute
with Grid freezer power do
Turn on;
if
Temp_Freezer (temperature1)'s temperature is less than 4°F (s/b -4F)
then
Turn off;
