Hi,
I’m about to build a vacation house piston, that replicates the house being occupied. I am aware that there are various Smartthings Routines that do this, but I thought I’d have a crack and writing my own.
What I’m trying to ascertain is whether Webcore will allow me to have a ‘master’ piston that will fire and forget other pistons (which may run for a couple of hours) before being terminated by the ‘master’ piston.
So, as an example of behaviour :
- Master Piston will trigger because house is dark, and away switch is set.
- that In turn, will trigger a number of other pistons. Using Random Wait, these will , as an example, replicate movement through a house by orchestrating set of lights being turned on and off, (eg, hallway, stairway, bathroom turned on in sequence, then turned off in reverse sequence) or show intermittent occupation of a kitchen with lights.
- At an appropriate stage in the evening, those pistons will be killed off, and nighttime pistons will be triggered instead (bedroom lights, bathroom visits, landing lights, etc).
- At the appropriate time, stop the ‘child’ pistons.
Thanks in Advance!
