I’m trying to use rangeValue to change the header of the gauge to read Winter/Spring/Summer/Fall based on the number of days in the year
According to the number of days in the year, the gauge header should read (0-91) “Winter”, (92-182) “Spring”, (183-274) “Summer”, (275-365) “Fall”
Can’t get the variables to work correctly.
[EDIT] I guess I should tag @WCmore, since it’s his tile I’m trying to recreate.
| +6ms | ╔Received event [Home].test = 1616256501948 with a delay of 1ms,canQueue: true, calledMyself: false |
| +49ms | ║RunTime initialize > 48 LockT > 0ms > rtDT > 32ms > pistonT > 31ms (first state access 16 7 41) |
| +52ms | ║Runtime (7934 bytes) successfully initialized in 32ms (v0.3.113.20210211_HE) |
| +52ms | ║╔Execution stage started |
| +55ms | ║║Cancelling statement #1’s schedules… |
| +65ms | ║║Calculating (integer)0 |
| +67ms | ║║Calculating (string) + (string)0 >> (string) 0 |
| +69ms | ║║Calculating (string) 0 + (string) >> (string) 0 |
| +81ms | ║║Calculating (string)79 + (string) " Days" >> (string)79 " Days" |
| +85ms | ║║Executed virtual command setTile (1ms) |
| +92ms | ║║Calculating (string)Days of the Year: + (string)79 >> (string)Days of the Year: 79 |
| +93ms | ║║Executed virtual command setState (0ms) |
| +96ms | ║╚Execution stage complete. (44ms) |
| +98ms | ╚Event processed successfully (97ms) |
