This is a cut simplified version of an issue I’m having. This piston is giving inconsistent behavior. Is this the wrong design? I know this will work if I put the SMS inside the do-every statement. I like having it this way because it makes it easier to test. If this is not a good design, then I’ll probably move the body of the piston to another piston and just call it within the do-every statement. This same behavior happens even if the time interval is longer, like once a day.
Send an SMS every minute.
It sends an SMS about two or three times in a 24 hour period.
(UPLOAD YOUR IMAGE HERE)
6/4/2019, 7:54:44 PM +266ms
+1ms ╔Received event [Home].time = 1559696084700 with a delay of -434ms
+109ms ║RunTime Analysis CS > 23ms > PS > 36ms > PE > 49ms > CE
+112ms ║Runtime (36620 bytes) successfully initialized in 36ms (v0.3.10c.20190522) (110ms)
+126ms ║╚Execution stage complete. (14ms)
+128ms ║Setting up scheduled job for Tue, Jun 4 2019 @ 7:55:44 PM CDT (in 60.307s)
+136ms ╚Event processed successfully (135ms)Preformatted text
