I have a piston called: Secure House that I run at night. “Secure House” is a sim switch in SmartThings (So: Hey Google, turn on Secure House). When it runs, it turns off a bunch of lights (if they’re on) and locks two doors (in case I forgot). Then the sim switch turns back off.
I had a device, a zwave light switch, go offline a few days ago for some reason. So Secure House would work up until it reached the point in the list of devices in the piston where it was (which was now a string of numbers) and stop, not turning off any other lights after it in the piston.
I unlearned/relearned the switch, corrected the piston, but the piston still stops when it hits that point.
I BOLDED in the below error log where the error occurs.
The piston shuts all lights/locks doors.
stops where device went bad and was relearned/reentered.
7/24/2020, 11:28:16 PM +635ms
+1ms ╔Starting piston… (v0.3.110.20191009)
+790ms ║╔Subscribing to devices…
+799ms ║║Subscribing to Secure House.switch…
+897ms ║║Subscribing to Alcove Fan…
+898ms ║║Subscribing to Alcove Light…
+899ms ║║Subscribing to Attic Light 1…
+900ms ║║Subscribing to Back Yard Light…
+901ms ║║Subscribing to Basement Door Light…
+903ms ║║Subscribing to Curio Cabinet Light…
+905ms ║║Subscribing to Dining Room Light…
+906ms ║║Subscribing to Dog Yard Light…
+907ms ║║Subscribing to Driveway Light…
+908ms ║║Subscribing to Front Door Light…
+909ms ║║Subscribing to Furnace Room…
+910ms ║║Subscribing to Garage Driveway Light…
+911ms ║║Subscribing to Garage Light…
+912ms ║║Subscribing to Kitchen Door Light…
+914ms ║║Subscribing to Kitchen Light…
+915ms ║║Subscribing to Left Deck Light…
+916ms ║║Subscribing to Living Room Light…
+917ms ║║Subscribing to Living Room Light Two…
+918ms ║║Subscribing to Right Deck Light…
+919ms ║║Subscribing to Sandblaster Light…
+920ms ║║Subscribing to Sink Light…
+921ms ║║Subscribing to Stair Light One…
+923ms ║║Subscribing to Stair Light Three…
+924ms ║║Subscribing to Stair Light Two…
+925ms ║║Subscribing to Studio Light…
+926ms ║║Subscribing to Upstairs Bathroom Light…
+927ms ║║Subscribing to Front Door Deadbolt…
+928ms ║║Subscribing to Kitchen Deadbolt…
+929ms ║╚Finished subscribing (149ms)
+954ms ║Cancelling condition #2’s schedules…
+955ms ║Cancelling condition #1’s schedules…
+977ms ╚Piston successfully started (975ms)
7/23/2020, 11:24:40 PM +399ms
+2ms ╔Received event [Secure House].switch = on with a delay of 124ms
+131ms ║RunTime Analysis CS > 27ms > PS > 50ms > PE > 54ms > CE
+134ms ║Runtime (38844 bytes) successfully initialized in 50ms (v0.3.110.20191009) (131ms)
+135ms ║╔Execution stage started
+142ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+144ms ║║Cancelling condition #2’s schedules…
+145ms ║║Condition #2 evaluated true (6ms)
+146ms ║║Cancelling condition #1’s schedules…
+147ms ║║Condition group #1 evaluated true (state changed) (8ms)
+149ms ║║Cancelling statement #3’s schedules…
+1336ms ║║Skipped execution of physical command [Alcove Light].off([]) because it would make no change to the device. (3ms)
+1337ms ║║Executed [Alcove Light].off (5ms)
+1343ms ║║Skipped execution of physical command [Back Yard Light].off([]) because it would make no change to the device. (1ms)
+1344ms ║║Executed [Back Yard Light].off (3ms)
+1350ms ║║Skipped execution of physical command [Basement Door Light].off([]) because it would make no change to the device. (2ms)
+1351ms ║║Executed [Basement Door Light].off (4ms)
+1371ms ║║Executed physical command [Curio Cabinet Light].off() (17ms)
+1372ms ║║Executed [Curio Cabinet Light].off (19ms)
+1378ms ║║Skipped execution of physical command [Dining Room Light].off([]) because it would make no change to the device. (2ms)
+1379ms ║║Executed [Dining Room Light].off (4ms)
+1385ms ║║Skipped execution of physical command [Dog Yard Light].off([]) because it would make no change to the device. (2ms)
+1386ms ║║Executed [Dog Yard Light].off (3ms)
+1391ms ║║Skipped execution of physical command [Driveway Light].off([]) because it would make no change to the device. (2ms)
+1392ms ║║Executed [Driveway Light].off (4ms)
+1398ms ║║Skipped execution of physical command [Front Door Light].off([]) because it would make no change to the device. (1ms)
+1398ms ║║Executed [Front Door Light].off (3ms)
+1404ms ║║Skipped execution of physical command [Furnace Room].off([]) because it would make no change to the device. (2ms)
+1405ms ║║Executed [Furnace Room].off (4ms)
+1411ms ║║Skipped execution of physical command [Garage Driveway Light].off([]) because it would make no change to the device. (3ms)
+1412ms ║║Executed [Garage Driveway Light].off (4ms)
+1417ms ║║Skipped execution of physical command [Garage Light].off([]) because it would make no change to the device. (2ms)
+1418ms ║║Executed [Garage Light].off (4ms)
+1424ms ║║Skipped execution of physical command [Kitchen Door Light].off([]) because it would make no change to the device. (2ms)
+1425ms ║║Executed [Kitchen Door Light].off (3ms)
+1431ms ║║Skipped execution of physical command [Kitchen Light].off([]) because it would make no change to the device. (2ms)
+1432ms ║║Executed [Kitchen Light].off (4ms)
+1439ms ║║Skipped execution of physical command [Left Deck Light].off([]) because it would make no change to the device. (4ms)
+1440ms ║║Executed [Left Deck Light].off (5ms)
+1456ms ║║Executed physical command [Living Room Light].off() (13ms)
+1457ms ║║Executed [Living Room Light].off (14ms)
+1463ms ║║Skipped execution of physical command [Living Room Light Two].off([]) because it would make no change to the device. (2ms)
+1464ms ║║Executed [Living Room Light Two].off (3ms)
+1465ms ║║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
+1467ms ║╚Execution stage complete. (1332ms)
+1468ms ╚Event processed successfully (1468ms)
7/22/2020, 11:25:05 PM +159ms
+2ms ╔Received event [Secure House].switch = off with a delay of 124ms
+117ms ║RunTime Analysis CS > 26ms > PS > 43ms > PE > 47ms > CE
+119ms ║Runtime (38839 bytes) successfully initialized in 43ms (v0.3.110.20191009) (117ms)
+126ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+128ms ║║Cancelling condition #2’s schedules…
+129ms ║║Condition #2 evaluated false (4ms)
+129ms ║║Cancelling condition #1’s schedules…
+130ms ║║Condition group #1 evaluated false (state changed) (7ms)
+132ms ║╚Execution stage complete. (12ms)
+133ms ╚Event processed successfully (133ms)
